I have got my hands on the latest release from garrett.
i need a 25mm spacer between the turbo and the manifold,
and i need to fabricate a dump pipe but apart from that everything i had for the gt30 will plumb straight
in. I picked the .82 a/r so i will be very interesting to see the results.
here's a couple of pics. looks good
Edited by dangerman4
  • Replies 151
sorry
i just checked and my bad.
8mm is the dump flange bolts.
the t3 base bolts are 10mm.
and yes once it is spaced away from the manifold there is heaps of room.
i will start taking some progress pics when i get home from work.
Is this the internally gated T3 housing that Garrett have been promising all year, and part of last?
What is the used unit beside it? It appears to have a Garrett logo on the compressor housing too.
And most importantly, can you post up the CHRA ID tag number too please?
I'm going to be interested in the progress pics.
cheers
cheers
Yes very interesting , hope they are available in quantity !
Dale the CHRA number would be the same for any cartridge with the same comp/turbine so its the complete assembly or unit number you want . Something worth noting is the part number stamped on the side of the exhaust housings mounting flange in the second shot . This would almost certainly be the turbine housings part number .
What I want to know is can these housings be grafted onto the GT37R cartridges because they have the potential to be better than the GT3540R cartridge for the larger/est RB - just need a suitable exhaust housing .
Cheers A .
Edited by discopotato03
Awesome news!!!!
Out of curiosity.... :(
Do they have a .63 internal gate gt3540?
Hi all , I got to look at a couple of these this afternoon - yep .63 and .82AR ratio .
The Garrett part numbers for the housings themselves (according to the packaging) is 771300-5 for the .82 and 771300-6 for the .63 .
The waste gate flat valve looks to be the same size as the IW GT28 housings and there is room for a larger disc as well . Doing a "high flow" on this valve is common practise on souped up XR6T's so no reason why these could not be modified the same way . BUT - always that but - the greater the area of the disc the more area exhaust manifold gasses under pressure have to work on to try and force it open . I kid you not and don't laugh , I've seen people using what looked like old bed springs trying to keep this valve shut .
The rule is if you run high boost pressure do everything you can to have the exhaust manifold pressure down somewhere near inlet manifold pressure . You don't need massive exhaust manifold pressure to drive the turbine just sufficient gas velocity by thermal expansion .
Back to those housings , Brett at GCG has I think five of each AR size ATM so be quick if you need one soon . Had I been better organised I would have had some pics but no doubt they'll turn up .
Cheers Adrian .
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
