Guy who used to go by AJHudson on another board, used to drive or still does drive an R33, white and a GTS-T I think.
I am getting his old email address soon and will post that but does anyone recognise that nickname and can get him to contact me or give me an email address/mobile????
Email1: [email protected]
Email2: [email protected]
I can't get responses from either email, all of this info is from paypal but the transactions took place over the time they will investigate for.
Edited by Midol
https://www.sau.com.au/forums/topic/134056-guy-who-goes-by-ajhudson/
Guy who used to go by AJHudsen on another board, used to drive or still does drive an R33, white and a GTS-T I think.
Try doing a search, just type the user name in.
I tryed & there is nothing there, u might be spelling it wrong
DD Phil on car audio australia knows him to some extent he always seems to coment on what this aj dude is selling and has done some recones for his DD subs so if you get in contact with him and explain everything you might get somewhere?
fill us in on what happened? how did he screw you over?
I've got his mobile off a guy who bought an amp off him.
If we can't get anything happening over the phone then I shall get hold of Phil.
I bought a GT-28 off him, through paypal. After a month I decided it wasn't coming to find he had been banned from CAA and paypal wouldn't do anything.
well that sux, I farkin hate thieves and scammers.
Paypal should have more information than just his email address.
For him to receive the money from paypal he has to register and verify a bank account or credit card details.
That obviously means that there is a paper trail, leading to a bank account which he would have needed ID to open.
Don't let it go, it is only a small amount of money, but it is the principal that counts. If he gets away with this how many other people is he going to rip off before he gets caught.
The good thing is though if he gets caught and ends up in jail, you can rest satisfied that he will be in for some group lovin'
Good luck with finding the prick
Wasn't through ebay :S
I don't support buying Car Audio gear through ebay (Though through a forum is really no different than ebay.)
Was second hand gear from a forum, CAA. I just thought someone might know him on here since he has a skyline. The CAA admin have been helpful but same as me, all emails unanswered - that mobile is disconnected. Name brings up nothing.
New lead though, might take a while for it to come through.
  • 3 weeks later...
Just updating now.
He claims it is at a store getting fixed - for 4 months.
Hired a personal investigator now, when I find his phone number I am giving him a call and letting him know he has 3 weeks to refund me the $820 + PI fees or he'll be seeing me in court and if that happens I'll be claiming legal fees on top.
Have had a consult with a lawyer - he told me not to add the lawyer fees onto how much he owes me yet, only do that if he denies to repay the money.
tell paypal he scammed you, they'll refund you the money. i know this from experience
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
