Hey forum just wanting to know whats the next best gear oil to get as my car has started to crunch just a bit from 1st to 2nd and 2nd to 3rd. It started happening after I changed my gear oil and I was told the other oil I put in may have been to thick. I put in castrol 80w 90 it was suggested that I put in a thinner oil preferrably the redline lightweigh shockproof oil but I'm in the Bahamas and I cant find it anywhere I wanted to know how thin on the weight oil I should go and if putting in a gear oil additive would help I see that lucas has one that I could add to the next set of gear oil I put in wanted to kno if that was a good or bad idea as well?
https://www.sau.com.au/forums/topic/134093-best-gear-oil/
Redline Lightweight Shockproof (smurfs blood) is great.
Only really recommended for worn boxes though. Heard that someone with a rebuilt box had issues.
I've got it in my car and it's brilliant.
www.nismo.com.au (unique autosports) is where I got mine done too.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2494837
Ok so Dont get he heavy shockproof for my problems get the lightweight? Also I see that redline has a superlight gear oil would this be better or just stick with the lightweight? What appilcation if not for my problem would the heavy shockproof gear oil be recommened for?
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2502059
I just put Motul Gear300 in my box. But I had no crunching issues so there was no way I was going to touch shockproof after some of the warnings I've heard on here about using them in mint boxes.
I'm still hoping the Gear300 improves the feel a bit, but the old oil was still in good nick so the difference will probably be minimal.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503128
MT-90 should be used in the gearbox and lightweight shockproof or 75w90 in the diff.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503190
Let us know how the Gear 300 goes Kinks.
aquariuz6, Shockproof is not for auto transmissions.
Daboss, heavy weight shockproof is for racing applications where the diff/trans sees very high temps. My bet is using on the street will result in worse shifting. Try the lightweight, as the super lightweight may be a tad thin.
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503294
Those are both redline products, and you've basically described what I'm using anyway (in terms of oil specs, ignoring brand).
Busty, I don't expect much to change really, my car has done < 40k kms and the old gearbox oil was still in good condition when I drained it this arvo. Preventative maintenance, really - at least now I know it has good oil in it and I won't have to worry about it for another 3-4 years!
Couldn't get the bastard diff plugs undone though, I'll need to get the car on a hoist so I can have a proper swing at it. The gearbox plugs came undone with just a ratchet :D
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2503558
On an auto box can you still use the redline lightweight shockproof or is it only for manual gearboxes? If no, Is there something as good as this oil for auto?
Id go for Castrol Transmax Z. Ive just changed my auto transmission oil to this and the car feels great. It aint cheap: 65 bucks for 4 litres of it and you need 3 bottles for a complete change...
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2505145
Noticeable improvement in cold and warm shifting, now it feels like sex. Good sex :nuke:
Big fan of Motul oil, which is ironic because they're French and we all know what french cars are like :)
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2517063
  • 5 months later...
MT-90 from Redline is for cars which don't have high k's. So i'd put the Mt-90 in my R34, not the lightweight shockproof.
Maybe that's why people with "new" gearboxes, etc... have had issues with the lightweight shockproof, because the synchro's are mint. MT-90 for the "lower" km gearboxes
https://www.sau.com.au/forums/topic/134093-best-gear-oil/#findComment-2943908
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
