Hey guys,
I've searched through various posts to try and find a solution but im just not sure if any of the other posts have the same problem.
I currently have a
1989 R32 gtst
Rb20det
3" hiflo cat and bee-r exhaust system (standard dump pipe)
HKS pod filter
Standard Bov
HKS spark plugs (havent changed since buying car as in good condition)
Standard Intercooler
Standard BOOST 9psi (spikes 10-11)
Since buying the car 5mnths ago it has been fine but for the last 2 weeks the car has been excessively backfiring,popping all over the place ( during gear changes, only when i come off throttle).
Its not missing during any part of the rev range but when i start the car its very lumpy, like barely wants to start running but then speeds up and idles fine.
It seems to be starting to lack power under full throttle and im abit worried about if it might be leaning out but i dont know how to check to see if it is.
Someone drove beside me the other day after following me up a hill and asked if my car was leaning out? They did say i wasnt blowing any black smoke under full throttle etc?
Im only a 2/3yr apprentice mechanic for kmart tyre and auto and I dont have the amount of $$ to get it on a dyno so was wondering if theres any way i can check stuff to see if certain things are working ok? my clutch is starting to slip alil so i have to save for that aswell so if anyone can help with any idea's or ways to help try and sort out whats going on would be greatly appreciated.
Many Thanks
Pete (BOOSTA) :cool:
https://www.sau.com.au/forums/topic/134095-standard-r32-gtst-problems-plz-help/
okay, you work for a kmart tyre and auto... do you have a pressure gauge at all around the workshop? if so, i would T that into the fuel line (between the pump and the regulator) and see what sort of pressures you are getting... sounds like it's possibly a fuel pump drama, might be getting towards the end of its life?
Thanks azzurra is there anywhere in specific to T into the line? and if i do what sort of numbers should i be looking at as ok?
The fuel pump im guessing will probably be standard like the rest of the car aswell. Thanks for your input!
to check mine, what we did was get a 'T' fitting.. on one prong we connected the gauge, to one side we connected a short length of fuel hose, and on the other side, we connected the fuel line from the pump to that (you disconnect this from the regulator, and replace it with the short piece of pipe that you just added to the T-piece)
then take it for a drive around the block, under normal driving conditions, and then under boost etc (get someone to come with you to read the gauge) and report back what you find....
from memory (don't quote me on this though, as it's only off the top of my head.... perhaps someone else can help out here) a 'healthy' figure will be around 3 bar (around 45psi) or so?
There is a bit of argument over what is best..
Spray on electrical contact cleaner is probably the best bet.. or some metho with a cotton bud or something - but just be really careful as the element is pretty delicate and can be snapped off.
The AFM effects idle, and also rich/lean mixtures, and some oil from the intake sometimes build up over time, which can muck around with that.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
