do you have the packaging for the lock nuts?
if you do it should have a code on there somewhere so that you can get replacement socket.
if you dont u will have to use an angle grinder to cut a slot in the nut and then get a chisel and hammer. put the chisel in the groove that is in the lock nut and hit it with a hammer to turn it.
other option is to weld a bar to the nut to turn it.
hope that helps
mmmm..
nah i dont have the package..
shit aye..sounds alot of work,, damnn, but nah thanks dude for the advice, so after i get the nuts out, where can i replace then? just rock up to anything wheel tyre shop get a new package i guess hehe
cheers
Hey guys, i lost my special tool to unlock a nut of the wheeel, therefore i cant even change tyres...
please advice...
Someone who knows what they're doing can remove a lock-nut in about a minute.
You just need to find a socket small enough that it needs to be hammered onto the nut, and fits tight enough so that you can turn it as normal.
Cheers :ermm:
places like bob jane actually put the lock nut code with your details in the computer in case you ever lose it. Of course thats about all BJ is good for. Try going back to the place you bought them if possible and seeing if they still sell it.
(ps when you get a new set make sure you write down the code and brand on your service records/similiar)
Put up apic of your locknut ( a clear close up) or P.M. a pic to me and i'll tell you the best way to get them off ( via P.M.). I dont want to put it up on the forum for obious reasons..
What the other guy said............just get a socket about the right size and smash it over the locknut with a hammer so that it fits tight, then undo it. Its not that hard.
A mate of mine went to beaurepaires and they charged him $50 to get them off. Would've been a lot cheaper to do it the other way.
Go to a tyre place and they'll get em off easy.
If you wanna do it yourself buy some el-cheapo softest metal you can find socket that'll go over it and smash it on with a hammer. Use that for the rest of the wheels. Playing with really big screwdrivers can do it as well.
Just drive your car to the dodgiest looking suburb in town... kick back in a deck chair a good 50m or so away, crack a beer and wait. Some locals will come along and have them off in a jiffy!
...important to stay alert though... so not TOO much beer... (boy that caught me out once)
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
