I've got a 2 way diff and I'd want the backlash set right so I'd have to get my diff man to set it up but I'm trying to find out which ratio is going to be best for drift with my new engine or if I should just leave it how it is.
Thanks guys
  • Replies 188
Posted Images
stock gtst is 4.3, which i have and ive got no probs with holding 3rd or 4th with that, i i had even more torque again (like what you have planned) i would change my diff to a 4.1
3.9 isnt really needed, bugger all difference between a 4.1 and a 3.9 anyway and 3.9's are a lot harder to come by.
  • 3 weeks later...
Conversion was successful today, took many hours a bit of swearing, welding, tapping, grunting. Most annoying part was that the rear section of my tailshaft was 17mm too short!! wtf?! will be taking that back to be rectified during the week.
280kmh dash is sweet and my guesstimations for 3.9 diff + 17T Navara cog were correct, speedo reads high by 10kmh :(
Nope, I'll try to remember to take some next time it's on the hoist.
Basically got some flatbar, cut 2 pieces, marked the holes, drilled them, bolted it up to the car with the flatbar in between, tac'd it, took it off and welded it.
wow complicated. :/
I slide the gearbox rubber mount towards the front of the car so that the middle hole in the std xmember lined up with the rear chassis holes. Then simply drill new holes in the gearbox so you can bolt the gearbox to the rubber mount.
I then bought a $2 piece of 4mm plate, drilled 3 holes, bolted the front chassis hole up to the plate directly then the xmember's middle hole bolts through the bar in to the chassis. The xmembers rear hole requires a nut with a little locktight.
Slap a little sound deadening spray crap so it matches the rest of the floor pan and its extremely difficult to pick.
I'll grab some pics soon.
Hey, i posted a question last week about my geabox getting stuck in reverse. The cause of it was that the speedo sender shaft actually snapped and left the nylon gear (and half the shaft) in the gearbox.
Ive got an R33 box in an R32 and have done the Navara sender and standard r33 gear swap.
My question is: How do i ensure that this doesnt happen again? When i installed the navara sender originally, i didnt notice that the shaft was off centre. Has this got something to do with it. Do i have to rotate the sender in the gearbox to a particular position?
I ordered the navara sender for $50 and the R33 nylon gear for $60 from Hornsby Nissan today.
Thanks,
Shaun.
wow complicated. :D
That sounds more complicated than my way :) we had a 32gtst w/26 in the shop so just copied that setup but with thicker flat
When you put the nivara drive in did you rotate it 180 degree's and re-slot it?
Nope, my impression was that was for 23T (bigger gear) so it doesn't push as hard against the pinion. My mechanic has been running a standard 17T Navara sender in his 25 box for years with no problems.
Edit: I'm more worried about the funky bends in the brand new speedo cable :/
Edited by bubba
No i didnt. Why do you do this? Is it so that the larger gear doesnt push as hard on the gear in the box?
I can only assume that the shaft snapped because there was too much lateral force on it. Or it was wabbling around in there.
I suppose another alternative is to just use the Navara gear and have the speedo recalibrated (or live with it).
Thanks,
Shaun.
Mate, so your speedo doesn't work? that explains the steering going heavy after a few mins.
No, No, it only just stopped working. The sender must have only just snapped. The speedo worked ok but i still had no power steering.
Shaun.
It's just like setting up the spur gear on your r/c car :thumbsup:
^^^I dont understand what that means at all!
Anyway, i did the mod last night and put the sender with the new gear into the box in the new position (180 degrees rotated). When i turn the main shaft in the gearbox, the speedo sender rotates, so i can only assume it worked ok. Fingers crossed. The tutorial from Cubes was soooo handy; thanks mate. I didnt bother about using a circlip on the end of the shaft though. It was an extremely tight tolerance fit, so i dont think it will work its way off. What do you guys reckon?
Shaun.
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
