  • Replies 188
Posted Images
Classic length on a skyline regardless of 4dr or 2dr is the same and i think the cefiros and laurels are quite similar also so thats positive.
Ive got both a skyline and cefiro driveshaft downstairs so will compare them and post up for everyones reference.
Cheers
  • 1 month later...
25 box going in soon and am trying to get my head around this whole speedo drive deal..
Question I have is: what final drive ratios does the Navara 17T gear suit?
Question 2: anyone know how many teeth are on the worm drive in the gearbox?
Apparently. My mates auto-eleccy said bring it down and he'll fix it up for me. Now that I need to throw a 25 box in (current box has started making some not-very-nice input shaft bearing noises after boxing day burnouts) I figure I'll either try to solve it with a correct toothed speedo cog, or just do what everyone else has done and get the auto-eleccy to fix it.
Cya in an hour or two avrahan :rolleyes:
Cheers, read that earlier in between work stuff but must have missed the bit at the top.. so 4.3 is 21T, 4.1 is 20T and 3.5 is 17T. Logic dictates that I would need 19T for 3.9s.. anyone know if a 19T cog is available?
Spoke to the parts guy at my local Nissan when I picked up my waterpump on the weekend.
Apparently you used to be able to get a whole Navara sender with a 19T cog, can no longer get the whole assembly though so he's ordered me a Navara housing and a separate 19T cog, will find out next week if the cog is the right length and cut the right way. Fingers crossed :D
What crown wheel should I run for the new rb30det?
Anyone know how much there worth?
Are you asking what diff ratio to run?
I run 3.9s and really like them, acceleration isn't as brutal as the 4.3s but it's much more usable and all round a lot nicer to drive.
If you change crown wheels, you need to change the pinion gear aswell, best way I found to do this is get an S13 diff with good pinion bearings and swap that into your 32 (only thing we kept was the 32 backing plate).
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
