like i said, we really didnt do anything that could have fixed any problem...I'm not exaggerating when I say all we did was take it all off, look at it, and put it back on :)
I feel that testing in a lower gear like 2nd is better, because its more likely to spike as it builds boost so fast that way...also pretty limited for space, and getting past 4500rpm in 3rd and 4th gear leads to some pretty high speeds...
