Ok here goes, deep breath.
Car is R34 GTT, was auto running a ROM tune. Ran fine, 255rwkw.
Got manual conversion. Was supposed to get z32 AFM fitted and pfc tuned but dyno broke so took Z32 and pfc back out and back in ROM tune and stock AFM.
Car ran fine, some hesitation and very rich but went ok at all boost levels.
Got Z32 refitted and PFC fitted and tuned. 11.8:1 AFR. Ran nice for a couple of days.
Started getting high knock levels.
Took to a dyno where it ran 225rwkw and pinged and was rich off the scale.
Suspected AFM was faulty as voltages seemed high for any given rpm/boost level.
Seemed to get gradually worse. Day by day dropped the boost a little until it was 7 psi. No pinging there.
Changed z32 for another - no fix.
Found dodgy looking wiring to new afm. PFC was getting some voltage even with engine off. Told that PFC had been shorted by dodgy wiring. PFC sent to be fixed. Wiring fixed.
Put old ROM tune (stock chipped ecu) and stock AFM back in thinking it would run fine as it did before but it didn't. Pinged and rich as hell at 12psi.
Tried swapping CAS for a known good one. No change.
Checked base timing at various stages, fine.
So we have audible pinging at anything over 7psi. It's not leaning out, in fact it's very rich. It does it with PFC or ROM tune. Does it with 3 difference AFM's. Does it with 2 different CAS'.
What am I missing here?
ive got no experience with the pfc so if its that someone else will have to help you out.
it could be your timing.
base timing on an auto is 20btdc, base timing on a manual is 15btdc. has that been sorted?
is the person that checking the timing leaving the clip that goes on the trigger wire open and not clipped?
my timing was off by 10 when i had the clip clipped.
There was something (on here?) in the last week or so that V RICH mixtures can also cause pinging. Have you checked all the PFC maps? Fuel pressure?
The safest way to check timing is to insert a lead between #1 coil and #1 spark plug.
Yeah I've gotta get a lead to use for that. Do you think Repco or whoever would sell them?
I've been told less than 9:1 AFR can cause pinging. Haven't checked fuel pressure yet.
Didn't bother with pfc maps as it happens with both the pfc and the rom tune.
Wow, this is going to be a guessing competition. Rich running is either too much fuel or not enough air.
My first guess would be the AFM/wiring, check the linearity of the AFM voltage at the ECU. It should be smooth/progressive as you increase the engine load.
My second guess would be to agree with Dunk, check the linearity of the TPS voltage. It should be smooth/progressive as you open the throttle.
Third guess, air leak somewhere after the AFM and before the inlet valves. More air is being measured (by the AFM) than is actually getting into the engine
Last guess is excessive fuel pressure, maybe the return line is blocked or the FPR failed. A quick check of the fuel pressure should reveal all.
Please let us know what you find
:rolleyes: cheers ;)
No the AFM output does not look ok. The Z32 was showing 1.3 volts at idle and I'm told it should be between 0.8 and 1.1 but I didn't check the RB25 AFM to see what it was reading nor do I know what it should be reading.
Also the z32 seemed to shoot up fairly quickly to 4.x volts but then take a while to go any higher. It was doing this even at 7psi of boost.
I'll check the things mentioned there tonight thanks guys.
yeah 1.3 at idle does sound high
im not sure the stock afm is that high at idle
yeah can u confirm vg30 is selected in AFM
also what are the % corrections on the airflow table
what does a map tracer look like for a dyno run ?
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
