yep fred from pro trans did the box for me i think its gonna be a big difference especially with the trans brake neva used one .. has anyone here used a trans brake whats it like...
Edited by campbell
  • Replies 74
the hardest thing about using a transbrake is getting used to not hitting the brakes when you hold it flat but its easy
just get into stage hold the button until you hit the right boost or rpm
i leave the line at 5000rpm with 10 psi boost
any questions pm me
put a boost gauge and 5" rev tacho close to ur steering wheel so u can c it straght and clear. I have 3 speed in mine. 1st u switch your transbrake solenoid on, hold the button then rev it to 5,000 or something, boost will hit 15-18psi. leave the button then you'll get "quickest launch ever". dont hold that button for too long, 5-6 sec max, other way u will cook ur trans. get a big trans cooler !, and dont press it again when you launch, your trans will go back to reverse and brake ur auto internals. autos are jsut like a tune and engine, you need correct stall size to suit ur turbo, and cam and then retune it to match everything... very hard man. You bought the best auto for drags, good luck
Love the sound of the T51R, always have and probably always will :P
As for being the quickest, I'm not sure about times but there was an R33 running a factory-capacity RB25, making 795rwhp getting around Brisbane, was built by Hardcore before they ceased operations and had NIS33 on the plates. Also, 40RCD (now TRY09) might be worth checking too, I don't know if it still runs an RB25 bottom end but last time I saw it, it was running some very decent times. It was definitely 2.5 litre when it was running mid 10's, and I'm fairly sure it was still 2.5 when it broke into the 9's too, but I don't know about now :)
Best of luck ;)
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
