Heres a link to one of the companys that do urethane injection. you basically drill some holes in your side sills and b pillars and pour in the mixture that hardens inside and stiffens up the chassis.
these guys sell it for 19000yen and another 50000 to 60000yen for putting it in your car, or you can DIY but if you make a mistake while putting it in the sills it is impossible to remove.
All the positive reviews ive read are from people who've used it and had success. All the negative reviews are from people that havent tried but point out all the things that could potentially go wrong with it
lol, well I've done it but got no feedback yet, the car is awhile away from the track...we just used boring old heatproof expanding foam. Sills, A and B pillar and chassis rail (still to go)
did it on the ae86 without any other forms of bracing (only because it was gonna be acid dipped) as a test.
Flex was about 10mm along the B pillar with a jack on full height under the engine crossmember without any form of bracing.
with the urathane expanding foam in the door rails flex was 6mm.
with the roll cage mounted, the flex was 1mm.
I didn't find it doing wonders for the car, a good solid rollcage is much better IMHO. If you are gonna use it, make sure its not a polymer (urathane has many different variants) that absolbs moisture... although the whole idea of expanding foam is the air bubbles in it, which could be home to condensation.
obviously welding it would provide more strength and a permenant fixture...however if it needs to come out at somestage then its gonna be a bitch. Bolting might be the case then. Personally i would weld it in, but im a fabricator so im completely biased haha.
  • 3 weeks later...
Sorry Duncan, never answered. I've never done it and find the concept difficult to explain in the lack of structural improvement it will offer other than crush resistance. A cage and seam welding/added stiffening is the only solution.
The only ways to measure a real difference are to use a calibrated floor and point measure device or a chassis dyno. In a sloppy car it may help, but there are other more realistic ways of dealing with sloppiness.
    • It will sound tragic and you wished you didn't have 1x exhaust per turbo. There's a reason why most S55 owners change to a single mid pipe.
    • Echo the comments about the well preserved condition it's in. It has the aero bumper too for extra points. Nice car, and please keep it like that! 🙂
    • 1. There are no real performance benefits. It sounds different, and as the pipes are not as large diameter you can claw back some undercar clearance or run lower (if that's your thing). 2. Twin pipes, offering exactly the same cross sectional area as a single pipe** will have higher pressure drop - so will not flow as well. That's because there is more surface area of wall per cross sectional pipe area, hence more frictional losses. ** But of course, it is almost impossible to get 2 pipes that are exactly the same XS area as a given typical single pipe. eg, 2x2" is not the same as 1x 3", although it is close. If the 2x pipes add up to less XS area than the single - it will just be flat out worse. If the 2x pipes add up to a bit more than the single, then it might come out as a wash. If the 2x pipes are substantially more XS area than the single, then it will probably flow a little better. 3. No. Why would there be? What have cats got to do with boost creep?*** ***But for f**ks' sake, please run a cat. 4. If you want.
    • UPDATE: was able to have the bracket repaired and base repaired, seat is like new now ;)
    • I was going to say it looks right out of Gran Turismo photoshoot when you just buy the car. (in a good way)
