i think that your power aspirations are a key factor in SMIC vs FMIC. personally, i am looking at around 200rwkw, with an emphasis on response which i believe will be well within the range of my trust cooler. furthermore, i'm hoping to do that with as little boost as possible, but we shall see :woot:
digging through the memory archives, SydneyKid did a comparison some time ago where he upgraded his stagea sidemount to an R34 sidemount and was able to generally work out the extra volume and flow requirements for his power goals, and i tried to apply the same formula to my new trust one from the standard one and worked out that assuming at least the same flow rate across the core from old to new, it would be conservatively capable of up to 220rwkw, well within my requirements.
strydes, i'll eat my shorts if you don't make +200rwkw (allowing the turbo is up to it).
make sure you at least pm me when you get the powerFC installed/tuned
well if it isn't my 'coolers old owner! mate i will definately let you know how i go on monday, maybe send through a dyno sheet depending on how it turns out :)
back on topic though, fEkuaR, i think most here would agree that if your side mount is an ARC unit, it should be good for at least 220, up to maybe even 240rwkw, so if your going to stay in that range, keep it.
well if it isn't my 'coolers old owner! mate i will definately let you know how i go on monday, maybe send through a dyno sheet depending on how it turns out :O
Thats will be all ill ultimately be after so we will see how it goes :ban:
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
