I just got my car back recently, noticed a few things wrong with it.
Feels like its struggling and on 5 cylinders.
Before someone says coilpack it struggles throughout the rev range, low and high rpm.
I have gotten it back from the panelbeater since I got a respray. I also got them to install my fmic and highflow turbo.
Once I got it back I noticed that my turbotech boost controller was missing its spring, they must have opened it and lost it.
I have the usual mods like full 3" exhaust, front/dump, remapped ecu.
What is the worst thing that could happen if the boost controllers spring is missing?
I have removed it and put it back to the stock setup, still that didn't solve the struggling engine problem.
And when the boost controller was on or even the stock setup, on the boost guage it wont even go above 0. Its like its restricted from going past it because when you drive it, the gauge will quickly go to 0 then stop there.
Does anyone have any ideas?
The last resort I want to do is to give it to a specialist and all he would probably do is to go through the whole list of a 100k service to figureout the problem. Well thats what the panelbeater told me to do anyways, It might just need a tune
https://www.sau.com.au/forums/topic/134316-stock-boost-gauge-wont-go-past-0/
ok this is most likely a very simple fix
firstly, with the boost controller having no spring it essentialyl is working as stock. the spring is what makesthe boost what it is!
now for the rough runnign and no boost.. options as to what it is:
- intercooler hose loose / clamp on too loose
- intercooler hose with a crack in it
- AFM giving problems
what to do?
first, try cleaning the inside of the AFM with a few sprays of brake cleaner
next, take a torch and look over the car at the intercooler clamps to make sure all the hoses are on right. check in the front bar too and thay are hard to see.. most likely that this is the problem...
best of luck,
Warren
Firstly if a coilpack fails completely can miss anywhere in the rev range. Is the engine receiving boost? The Gauge will do that when the turbo is making no boost or its not getting to the engine.
what to do?
best of luck,
Warren
Thanks Warren,
I am waiting on another turbotech boost controller. I was wondering since I'm just missing the spring could I just get a spring from the hardware store or is there special tensions to the turbotech ones?
I will have a look at the intercooler and fmic hoses soon.
I'll get back to you once I check.
Thanks, mate
If you replaced the boost controller with the stock one and you still had the problem then clearly its not the boost controller. Firstly like warren said check all the intercooler piping connections. It sounds to me that your engine is not receiving boost. Without boost a gauge will read as you described.
Hey So Godzilla32,
I just checked the intercooler piping, I just tightened the hoses to its limit. There seems to be no cracks on the hoses either so I guess it could be the afm?
I only checked by revving it, but now I get that fluttering sound which is normal, even though I have the stock setup and panel filter, most likely the intercooler just made it louder.
Although it sounds all normal, does this still mean that the engine isn't getting boost?
Only revved it(no driving) the boost gauge still didn't go past 0 mark. I know only way to check though is to drive it because it shouldn't go over 0 in the 1st place on neutral right?
make sure that the AFM's connected up, i forgot it once and it was bearly running, ideally u should take it back to the ppl that dont the cooler and turbo, n say what the hell have you done, n get them to fix it
I was thinking this too. I wouldnt have driven very far before doing a u-turn...
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
