I just got my car back recently, noticed a few things wrong with it.
Feels like its struggling and on 5 cylinders.
Before someone says coilpack it struggles throughout the rev range, low and high rpm.
I have gotten it back from the panelbeater since I got a respray. I also got them to install my fmic and highflow turbo.
Once I got it back I noticed that my turbotech boost controller was missing its spring, they must have opened it and lost it.
I have the usual mods like full 3" exhaust, front/dump, remapped ecu.
What is the worst thing that could happen if the boost controllers spring is missing?
I have removed it and put it back to the stock setup, still that didn't solve the struggling engine problem.
And when the boost controller was on or even the stock setup, on the boost guage it wont even go above 0. Its like its restricted from going past it because when you drive it, the gauge will quickly go to 0 then stop there.
Does anyone have any ideas?
The last resort I want to do is to give it to a specialist and all he would probably do is to go through the whole list of a 100k service to figureout the problem. Well thats what the panelbeater told me to do anyways, It might just need a tune
https://www.sau.com.au/forums/topic/134316-stock-boost-gauge-wont-go-past-0/
ok this is most likely a very simple fix
firstly, with the boost controller having no spring it essentialyl is working as stock. the spring is what makesthe boost what it is!
now for the rough runnign and no boost.. options as to what it is:
- intercooler hose loose / clamp on too loose
- intercooler hose with a crack in it
- AFM giving problems
what to do?
first, try cleaning the inside of the AFM with a few sprays of brake cleaner
next, take a torch and look over the car at the intercooler clamps to make sure all the hoses are on right. check in the front bar too and thay are hard to see.. most likely that this is the problem...
best of luck,
Warren
Firstly if a coilpack fails completely can miss anywhere in the rev range. Is the engine receiving boost? The Gauge will do that when the turbo is making no boost or its not getting to the engine.
what to do?
best of luck,
Warren
Thanks Warren,
I am waiting on another turbotech boost controller. I was wondering since I'm just missing the spring could I just get a spring from the hardware store or is there special tensions to the turbotech ones?
I will have a look at the intercooler and fmic hoses soon.
I'll get back to you once I check.
Thanks, mate
If you replaced the boost controller with the stock one and you still had the problem then clearly its not the boost controller. Firstly like warren said check all the intercooler piping connections. It sounds to me that your engine is not receiving boost. Without boost a gauge will read as you described.
Hey So Godzilla32,
I just checked the intercooler piping, I just tightened the hoses to its limit. There seems to be no cracks on the hoses either so I guess it could be the afm?
I only checked by revving it, but now I get that fluttering sound which is normal, even though I have the stock setup and panel filter, most likely the intercooler just made it louder.
Although it sounds all normal, does this still mean that the engine isn't getting boost?
Only revved it(no driving) the boost gauge still didn't go past 0 mark. I know only way to check though is to drive it because it shouldn't go over 0 in the 1st place on neutral right?
make sure that the AFM's connected up, i forgot it once and it was bearly running, ideally u should take it back to the ppl that dont the cooler and turbo, n say what the hell have you done, n get them to fix it
I was thinking this too. I wouldnt have driven very far before doing a u-turn...
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
