sorry for yet another hijack :laugh: , but is that autospeed fuel adjuster and boost controller thing as good as the pfc (when i comes to air/fuel tuning and boost controlling)? would this be recommended as my next mod since after installing and splitdump/front pipe im now running at slightly higher boost than normal.
hey lanky71, the first mod i did to my 34 was the FMIC and pod filter (yes i know its 2 intake mods but the 34 sedan is a sleeper kind of car, cops dont care too much where i am anyway :) ), then a split dump/front pipe and a custom catback system (including the cat, it came to about $650 - done by a local exhaust shop); and yes, i also got a bov and placed it in the 34 auto, bascailly i got sick of it after a few months and took it off ( its also a cop magnet) .
Edited by RyanN
Just a question... how'd it sound on an auto btw?
i reckon if u had to make the choice between a pod or a fmic, go the cooler. see what GTRgeoff has in his writeup on airboxes and get a good panel filter. My 2c
oh and geoff, that lock bar, good stuff mate. i love it! easy as to fit
the 34's came standard with the same bov as all the other rb20/25s, which is also the same as on a wrx (although the bolt holes are in different spots).
and the 1 intake mod doesn't apply in QLD either.
Hows it going mad? :O
the BOV was on the auto tranmission r34's as well? (i'm fairly new to nissan's)
I'll explain why i'm asking these questions (might not matter with newer cars, but i'll mention it anyway):
I had a mkIII supra previously (Ga70, 1G-GTE engine, Auto, used a MAF sensor not a MAP sensor like the 1JZ) and it did not have a stock BOV. I got a BOV put on next to the throttle body. I then added a cat back exhaust with HI Flow cat and a HKS superpower flow pod kit. Once that was done, did a dyno run and the car didnt perform as expected (almost worse acctually). Turns out the ECU could not cope with the now quicker and larger amount of air flying into the engine, and started flooding the engine with fuel (even had tiny droplets of fuel spluttering out the exhaust. A SAFC had to be installed to fix the problem and to make the most of the mods (got even more HP with the SAFC). After reading about it on the web, it seems that ECU cars without a stock BOV or with recirculation valve factor this in its air fuel calculations (is this true anyone?). Introducing a atmo BOV or POD kit threw these calculations out the window apparently. Again this problem plagued older ECUs, and i'm sure the r34's electronics are well advanced compared to a Ga70 supra, atleast i hope so *chuckle*.
Newer ECU or Not I'd still recommend get a SAFC when you start changing AF parts, purely to get the most of your mods.
Edited by Scratch
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
