hey guys my left parker light on the rears are out, i took off the plastic trim, and all i see is wirings goin into 1 small hole wif black rubber sealed around it, i tried using force, but it wouldnt come out and i dont want to use too much force incase i break something, how do i change the globes in it?
Hey 5ky,
Have you you successfully changed the globe? how did you do it? im also having trouble?
Also what globe did you buy to replace it?
edit: Just found this link which is useful :P
http://www.r34gtt.net/r34howtorearlights.html
Edited by blah_blah
yea, that link u provided is how i did mine
pretty simple lol
i just took out the blown globes and took it to the shops and look for the same one,
can anyone tell me the bulb needed for inner lights? I guess there's two bulbs in the inner light as it looks like a half moon at night at the moment.
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
