oh god bravestar, my cousin still has all the original figurines in packaging ..and as for the garbage gang, does anyone have pics of the original stickers, i love them when i was younger and would lvoeto see them again
https://www.sau.com.au/forums/topic/134378-old-skool/#findComment-2496503
We had the Garbage Gang in the UK, should have kept some of those.
Did we? Don't remember them, mind you Forces TV in Germany was 1 channel, so if they were around '75-'80 or '85-'90 I probably wouldn't have seen them.
We used to get most programs a week late, so any that had competitions we were stuffed, as we normally got to watch them the day after the competition closed. :dry:
I remember BraveStarr, but not when it was on, would it pre-date "G-Force - Battle of the Planets"?
Who could forget the inspiring opening narration? "Battle of the Planets! G-Force, five incredible young people with superpowers! And watching over them from Centre Neptune, 7-Zark-7! Watching, warning against surprise attacks by alien galaxies from beyond space. G-Force! Fearless young orphans, protecting Earth's entire galaxy. Always five, acting as one. Dedicated! Inseparable! Invincible!" (Yes I did have to look that up!)
And then we could get onto the likes of 'Blake's 7'........
https://www.sau.com.au/forums/topic/134378-old-skool/#findComment-2497283
We used to get most programs a week late, so any that had competitions we were stuffed, as we normally got to watch them the day after the competition closed. :D
You must be 10 years old than me! While I was an 8 year kid trading Garbage Gang cards, you would have been hooning around in an Austin Metro and discovering alcohol not looking at Garbage Gang cards! LOL! :dry:
I am talking about Garbage Gang cards like football cards BTW, I think you might be talking about a TV show?
https://www.sau.com.au/forums/topic/134378-old-skool/#findComment-2497455
yeah garbage gang were pretty cool
in the uk they were known as pail kids (go figure??)
Yep thats it! Garbage Pail Kids.
I remember one had a razor and was peeling skin off from somewhere, maybe face or leg.
https://www.sau.com.au/forums/topic/134378-old-skool/#findComment-2497760
You must be 10 years old than me! While I was an 8 year kid trading Garbage Gang cards, you would have been hooning around in an Austin Metro and discovering alcohol not looking at Garbage Gang cards! LOL! :(
I'm only 32 :O
I've just got a good memory for crap.
And I've never driven a metro! :P
https://www.sau.com.au/forums/topic/134378-old-skool/#findComment-2497834
i had stickers all over a timber board in my garage as a kid , but through it out , but i remember ones like 'crater face chris' who was a kid covered in pimples...im trying to think of others
edi: http://garbage_pail_kids.tripod.com/NZ_1st_Series.htm
Edited by mr_crust
https://www.sau.com.au/forums/topic/134378-old-skool/#findComment-2498825
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
