TAIL LAMPS $ 550 PAIR
DIFF RETAIL $3000 SELL $1200
REAR SEATS $ 600
STOCK SPRINGS $150
QUATER PANEL TRIMS L & R $ 150EA
TOP L QUATER GLASS TRIM $100
LEFT & RIGHT FRONT SEAT BELTS $150EA
REAR SWAY BAR LINK $100
HKS SUPER DRAGER REAR MUFFLER $200
REAR BRAKE CALIPERS AND ROTORS $300 PAIR
LHR SUSPENSION COMPLETE $880 ( DRIVE SHAFT NOT INCLUDED )
LH DRIVE SHAFT $380 !!! SOLD !!! IF ANYONE STILL NEEDS ONE GIVE THIS NUMBER A CALL 08 9248 1218 THEY HAVE A CAR FOR WRECKING
MORE PARTS WILL BE ADDED SOON PICS AVAILABLE ON REQUEST
Edited by GOT BOOST ?
https://www.sau.com.au/forums/topic/134390-r34-gtt-parts/
  • Replies 48
DO you have the rear section of the tailshaft?
If so how much?
No sorry i wouldn't have that.
West Coast Imports 08 9248 1218 have a complete car for wrecking.
https://www.sau.com.au/forums/topic/134390-r34-gtt-parts/#findComment-2512115
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
