Some weeks wednesday is also cheap, and saturdays. But by far tuesday most common cheap day as i think we all know. Some of the Indian guys that man my local Mobil like my car and tell me what days it will be cheapest heheheh :dry:
Edited by Xizor
Try www.motormouth.com.au - it's a fuel price-watching service.
Not all suburbs are listed and the lists within the suburbs are pretty scant. They really should try and get more servo stations on board so the list is bigger, and even the servos that are listed don't always give price information, which is a pain in the ar$e, but it might help some of you...
Parents got petrol today in Sydney around epping for $1.29 for Premium Vortex not 98 octane the standard premium... I got same petrol in Erina for $1.30.... Pulled up at the wrong pump as the servo only has one Octane 98 Vortex pump I now learn...
Drew.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
