First of all Welcome to SAU...
Both these oils are one of the best on the market, however Red Line in my opinion and the opinion of other mech/tuners I have spoken to, is over priced and not nearly as good as RP...
I just bought a 5L jug of RP 10W40 for my oil change and have found them at the following outlets:
Peps Auto - $75
Autobarn - $89 (will price match)
Click on this URL to direct you to the RP Distributor list Australia wide...
http://www.royalpurple.com.au/html/s04_ser...ices&dsb=25
P.S for future references, use the search button cause there is HEAPS of info already discussed on this site... ENJOY!
Regards,
Sarkis
Edited by QRI05E
Your onto the hi end synthetics there >_<. I run the Redline System right through and it has been Excellent. Car runs slightly lower temps under same conditions.
At about 135 dollars from Bursons for 5 litres because of odd size imperial packaging you need to think about it though.
For a skyline you need 1 x 4litre pack and a 1 x 1 litre pack.
Hi Bro,
I know I could get Redline from burson for about $27.00/quart. Me find it rather expensive, so trying to find out from experience forumers if they knew of any other supplier that could supply at a lower price, or the lowest price. Tryin to get a bang for my bucks.
Thank you for your feedback & help. Cheers !
Peps Auto - $75
Regards,
Sarkis
Its only selected Autobarns... however you can get RP from the following in Vic
Eagle Auto Spares
92 South Gippsland Hwy
DANDENONG
03 9793 5544
Sanmateo Performance Systems
19-21 Ninth Street
MILDURA
03 5023 7559
Cheers,
Sarkis
redline is a better oil than royal purple it is composed of a more expensive base which partially explains its more expensive price. it is the best oil you can buy. search for the goods on oils thread for more info, but i would say that you can get a similar performance oil to royal purple for less money.
HOw about Kendall Racing oil? It is made from pure Pensylvanian Crude and is one of the best oils around. There is actually a warning on the packaging stating that it must not be used to run an engine in as the engine wont run in due to the oil having such good lubricating properties.
Kendall is made by Conoco, pretty cheap and good. Mostly group III oil though.
Ok guys... this morning i put some Royal Purple 10W40 with a new cooper oil filter and this is what i have noticed after 100km/s of driving:
- Car idles MUCH smoother and quieter than when using Castrol R and Nuon (comparing to when oil was first changed with both brands)
- Car warms up much quicker on cold starts than before
- Car starts quicker and easier
- Exhaust note on idle is more deep and is not lumpy/poppy anymore
- Acceleration feels 100 times smoother and responsive than Casrtol R and Nulon
In conclusion, I recommend RP for any RB motor.. over any other oil i have ever used!
ROYAL PURPLE
A+++
Regards,
Sarkis
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
