First of all Welcome to SAU...
Both these oils are one of the best on the market, however Red Line in my opinion and the opinion of other mech/tuners I have spoken to, is over priced and not nearly as good as RP...
I just bought a 5L jug of RP 10W40 for my oil change and have found them at the following outlets:
Peps Auto - $75
Autobarn - $89 (will price match)
Click on this URL to direct you to the RP Distributor list Australia wide...
http://www.royalpurple.com.au/html/s04_ser...ices&dsb=25
P.S for future references, use the search button cause there is HEAPS of info already discussed on this site... ENJOY!
Regards,
Sarkis
Edited by QRI05E
Your onto the hi end synthetics there >_<. I run the Redline System right through and it has been Excellent. Car runs slightly lower temps under same conditions.
At about 135 dollars from Bursons for 5 litres because of odd size imperial packaging you need to think about it though.
For a skyline you need 1 x 4litre pack and a 1 x 1 litre pack.
Hi Bro,
I know I could get Redline from burson for about $27.00/quart. Me find it rather expensive, so trying to find out from experience forumers if they knew of any other supplier that could supply at a lower price, or the lowest price. Tryin to get a bang for my bucks.
Thank you for your feedback & help. Cheers !
Peps Auto - $75
Regards,
Sarkis
Its only selected Autobarns... however you can get RP from the following in Vic
Eagle Auto Spares
92 South Gippsland Hwy
DANDENONG
03 9793 5544
Sanmateo Performance Systems
19-21 Ninth Street
MILDURA
03 5023 7559
Cheers,
Sarkis
redline is a better oil than royal purple it is composed of a more expensive base which partially explains its more expensive price. it is the best oil you can buy. search for the goods on oils thread for more info, but i would say that you can get a similar performance oil to royal purple for less money.
HOw about Kendall Racing oil? It is made from pure Pensylvanian Crude and is one of the best oils around. There is actually a warning on the packaging stating that it must not be used to run an engine in as the engine wont run in due to the oil having such good lubricating properties.
Kendall is made by Conoco, pretty cheap and good. Mostly group III oil though.
Ok guys... this morning i put some Royal Purple 10W40 with a new cooper oil filter and this is what i have noticed after 100km/s of driving:
- Car idles MUCH smoother and quieter than when using Castrol R and Nuon (comparing to when oil was first changed with both brands)
- Car warms up much quicker on cold starts than before
- Car starts quicker and easier
- Exhaust note on idle is more deep and is not lumpy/poppy anymore
- Acceleration feels 100 times smoother and responsive than Casrtol R and Nulon
In conclusion, I recommend RP for any RB motor.. over any other oil i have ever used!
ROYAL PURPLE
A+++
Regards,
Sarkis
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
