  • Replies 40
i cant wait to see one of those maxda 3 turbo's worked too 250-300kw
FAAAAAAAAARRRK!
I wouldn't.
220kw is about the limit for a front wheel drive. Even prior to that you start to see hideous amounts of torque steer (plant your foot, go left!).
Its well known in the UK where they have many "hot" front wheel drives sold from manufacturers.
RWD and adjustable AWD for the win.
Haven't driven either of them, but independent testing shows the 3 MPS is in fact quicker...
At least in gear I reckon a 3 MPS would take off. The launch of the 6 MPS gives it the 1/4 time advantage. Roll on would be a different story.
Karen and I took an M3 (just for you Daveo :D ) MPS for a drive a week or two ago, and I have to admit I was more than a little impressed. I was a lot more impressed than I expected to be actually. That said, FWD dynamics don't really do it for me, and it apparently has a stability control thing in it, so I deliberately botched a corner entry to test it and it happily understeered towards the side of the road lol. In the rest of the corners it seemed to hang on quite well though, maybe they've tried to make the stability control not too intrusive? Powering out of a corner was frustrating but something I could live with given the rest of the package.
I thought the interior was fairly nice, the seats and pedal placement were good, the wheel is adjustable for reach and tilt and the dash is fairly easily readable. My only gripes were that some parts of the interior felt a bit cheap, and the clutch was really grabby, nearly as grabby as my old 5 puck brass button - it went from nothing to fully engaged in probably 10mm of pedal travel. This is fine if you're expecting to do a fair amount of track work or hard driving, but for a vehicle that I personally see as a quickish road car rather than something I'd be wanting to take to the track all the time, it's a bit annoying.
Gordo, peak power to weight doesn't tell the whole story, these things make stupid amounts of torque from 3k up until nearly the redline. In gear they are really quite impressive :(
but look at the 294nm of torque @ 4800rpm in R33 compared to 380nm @ 3000rpm in MPS...not that i would choose one over my R33 but its quite impressive
Which indicates the Mazda 3 has a higher average power over the rev range.
    • Goddam! Thats the dream, neo heads seem hard to come by these days though, best I've seen is $2-3k or there's a full motor for $7k atm
    • Cheers for the input, 450kw on poncams is impressive! I assumed you'd need 264 or 272 for that power level, good to know you don't need to rev that high to hit it, just don't want to buy the cams etc then find out the hydraulic lifters suck haha The box will be getting reconditioned too, possibly an aftermarket gearset if it turns out they're toast, cheers I'll keep that in mind
    • I think definitely get a manual oil pressure gauge on it then. Double check if it's really dropping pressure that low.
    • yes sorry i should of spoke better, all sensors are grounded into their specific homes in the ecu, the ecu is then grounded to the chassis itself along with the EFI relay.
    • I'll check the wiring plan tomorrow. Now when you say ALL the earth's are to the chassis, is that including the sensor ground from the ECU? Certain items should not be grounded to the car/body/chassis, they should ground back to specific ground pins on the ECU.
