  • Replies 40
i cant wait to see one of those maxda 3 turbo's worked too 250-300kw
FAAAAAAAAARRRK!
I wouldn't.
220kw is about the limit for a front wheel drive. Even prior to that you start to see hideous amounts of torque steer (plant your foot, go left!).
Its well known in the UK where they have many "hot" front wheel drives sold from manufacturers.
RWD and adjustable AWD for the win.
Haven't driven either of them, but independent testing shows the 3 MPS is in fact quicker...
At least in gear I reckon a 3 MPS would take off. The launch of the 6 MPS gives it the 1/4 time advantage. Roll on would be a different story.
Karen and I took an M3 (just for you Daveo :D ) MPS for a drive a week or two ago, and I have to admit I was more than a little impressed. I was a lot more impressed than I expected to be actually. That said, FWD dynamics don't really do it for me, and it apparently has a stability control thing in it, so I deliberately botched a corner entry to test it and it happily understeered towards the side of the road lol. In the rest of the corners it seemed to hang on quite well though, maybe they've tried to make the stability control not too intrusive? Powering out of a corner was frustrating but something I could live with given the rest of the package.
I thought the interior was fairly nice, the seats and pedal placement were good, the wheel is adjustable for reach and tilt and the dash is fairly easily readable. My only gripes were that some parts of the interior felt a bit cheap, and the clutch was really grabby, nearly as grabby as my old 5 puck brass button - it went from nothing to fully engaged in probably 10mm of pedal travel. This is fine if you're expecting to do a fair amount of track work or hard driving, but for a vehicle that I personally see as a quickish road car rather than something I'd be wanting to take to the track all the time, it's a bit annoying.
Gordo, peak power to weight doesn't tell the whole story, these things make stupid amounts of torque from 3k up until nearly the redline. In gear they are really quite impressive :(
but look at the 294nm of torque @ 4800rpm in R33 compared to 380nm @ 3000rpm in MPS...not that i would choose one over my R33 but its quite impressive
Which indicates the Mazda 3 has a higher average power over the rev range.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
