  • Replies 40
i cant wait to see one of those maxda 3 turbo's worked too 250-300kw
FAAAAAAAAARRRK!
I wouldn't.
220kw is about the limit for a front wheel drive. Even prior to that you start to see hideous amounts of torque steer (plant your foot, go left!).
Its well known in the UK where they have many "hot" front wheel drives sold from manufacturers.
RWD and adjustable AWD for the win.
Haven't driven either of them, but independent testing shows the 3 MPS is in fact quicker...
At least in gear I reckon a 3 MPS would take off. The launch of the 6 MPS gives it the 1/4 time advantage. Roll on would be a different story.
Karen and I took an M3 (just for you Daveo :D ) MPS for a drive a week or two ago, and I have to admit I was more than a little impressed. I was a lot more impressed than I expected to be actually. That said, FWD dynamics don't really do it for me, and it apparently has a stability control thing in it, so I deliberately botched a corner entry to test it and it happily understeered towards the side of the road lol. In the rest of the corners it seemed to hang on quite well though, maybe they've tried to make the stability control not too intrusive? Powering out of a corner was frustrating but something I could live with given the rest of the package.
I thought the interior was fairly nice, the seats and pedal placement were good, the wheel is adjustable for reach and tilt and the dash is fairly easily readable. My only gripes were that some parts of the interior felt a bit cheap, and the clutch was really grabby, nearly as grabby as my old 5 puck brass button - it went from nothing to fully engaged in probably 10mm of pedal travel. This is fine if you're expecting to do a fair amount of track work or hard driving, but for a vehicle that I personally see as a quickish road car rather than something I'd be wanting to take to the track all the time, it's a bit annoying.
Gordo, peak power to weight doesn't tell the whole story, these things make stupid amounts of torque from 3k up until nearly the redline. In gear they are really quite impressive :(
but look at the 294nm of torque @ 4800rpm in R33 compared to 380nm @ 3000rpm in MPS...not that i would choose one over my R33 but its quite impressive
Which indicates the Mazda 3 has a higher average power over the rev range.
    • I'm not doubting it does something, there's clearly a reason why Nissan bothered with it on the transmission/diff/transfer case but it's more just the effort of finding a drain plug that isn't going to have some unexpected design problem that makes me lazy. For example even the Nismo branded ones here spec way less than the factory 20 N-m. They say only torque to 10 N-m. That is getting absolutely trashed the moment you take it to any mechanic who isn't familiar with the specific requirements and assumes it should be torqued to factory spec.
    • Same same. DE block has no oil squirters though. You either live without them, or go to the effort of adding them. The type of pain is up to you.
    • Thanks for bringing this workshop to my attention, i didnt know about it before and Jessie did some Fabolous work on my car! Helps that its close to home as well, hate having to drive half way across melbourne for a decent workshop.  https://www.instagram.com/p/DIPwaQ1yHMe/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
    • Hi, doing a rb25de+t build right now on my r34 4door that got a 75t block, wanting to use rb25det piston but just want to confirm the 25det and 25de rod, crank are same?
    • If a magnet doesn’t stick to anything except another magnet then it’s not a very good magnet and is probably just a piece of steel
