Do you guys buy any of these to put in your car every now and then? I think im having a "buy as much shit as you can on your car" fever... i cant stop loooking for new things to buy... i just put some injector cleaner into my petrol tank. Might buy some octane booster later on for a dirty weekend drive!
i used nulon last week, not sure if it had anything to do with my car suddenly running like a POS but i used up the tank changed my fuel filter and it is back to normal - lots of shit was built up in the fuel filter i have a feeling that it may have broken that down a little and the put that into the enging or something? will probably buy another bottle tonight now that the filter is changed
octane boosters arent really good for engines as they can leave deposits n shit... there was a guy on here ages ago who took his turbo off and had crap in it n stuff from fuel additives and octane boosters. he took a pic, thats why i remember... anyhoo...
fuel injector cleaners are good to put thru an engine say when you first get it or sefvice or so. if they actually need to be cleaned the only way is to do it properly rather than just tipping a bottle of whatever into your tank.
octane boost should only really need to be used if you cant get decent petrol and you need to get home urgently. they are also good for when you want to sell your car and you want the engine to be a bit smoother than it is for test drives... most noticable on holen 202 engines :rolleyes:
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
