Hey all,
I took my car down to RE Customs today. Spoke to Ray who was cool and friendly about my results. Basically i got the stock boost level raised to 10 psi. I was told that the engine was knocking. Would knocking occur if the spark plugs weren't regapped? Also when i fully open the throttle the engine seems to splutter (mainly around 5000rpms) before revving clean to redline. Would this be caused by the plugs aswell?
My car is an auto 95 33 gtst. Mods are 3.5 inch cat back and POD. Boost was raised with a bleed valve.
Also what are your opinions on the dyno read out.
Thank you to all that reply.
https://www.sau.com.au/forums/topic/134479-got-my-car-dynoed-today/
shouldnt be knocking with those mods... as mentioned fuel pump would be the only reason as it should be rich as upping the boost
Also maybe look at getting a better bleed valve/boost controller looks like by the time you are making max power it has dropped back to 8.5psi
cant say for sure without seeing your afr but generally with those mods you would see you car richen up a fair bit eg maybe a 11:1 or 11.5:1 if you get the afr and it's above 13:1 i would get it checked out although any good dyno operator should have said something and stopped the dyno session.
But it's an easy task and worth checking anyways pull out your plugs check the gapping and check your coils are in good nick.
if its coffing and farting round 5000 u should gap ur plugs down mine r at .7 sum ppl say its to low but when i had same mods my car was doing this and that gap fixd it 100%
also if in doubt about the fuel pump put a fuel presure reg on it and up the presure to say 45 50 and see if that helps with the pinging if not could be shitty fuel mine knocks (pings) if i run optimax but 98bp ultamate it dosent
I'd think about closing the plug gap to 0.7 or 0.8, but at only 10psi I can't see this being your problem. If your getting a stutter at 5000 I'd be checking plugs, coils, fuel pump and injectors, make sure they are all working OK. I'd also be checking the simple things, air filter, fuel filter etc.
you are definetly hitting rich and retard
dont bother changing plugs or anything else
turn the boost down see if the problem goes away
if so, which im pretty sure it will, time for a piggyback, remap or stand alone ecu
Sorry for the late reply. I run my car on Bp ultimate. Seems to run better than any other fuel. So getting an SAFC should rectify this problem?
Thanks
Well yes but it still seems really low for 10 Psi. I hit 175 with standard boost, std cooler, pod and cat back. I wouldn't up the boost till you at least get a Hi-flow cat and perhaps a dump or split dump pipe. Seal up your plugs to be sure and you should be able to get close to 9Psi without even touching the boost controller.
Your plugs at 0.8 should be fine. Whilst .7 or .6 may seem to fix a problem, it usually only "covers it up". Find the cause of the issues rather than trying to cover them up methinks.
Checked my coilpacks and they seem to be fine, no cracks etc. My plugs are NGK iridiums which are only about 6000kms old. The air filters seems to be fine, its basically new, don't know about the fuel filter though. I haven't changed it since i bought the car 20,000kms ago but it was apparently changed before i purchased it. Gonna look at A/F ratio on monday. Could driving my car around temporary in this state potentially harm my engine? Also can ignition timing be cause of this problem? Does it have to be retarded or advanced when running more boost?
Thanks all
Unfortunately there isn't much you can do to fix the tune of your car without getting a power-fc or some other computer, the computer retards the timing and richens the mixture when it detects the car is running outside the factory specs(more boost).Cars with a catback exhaust can hit rick and retard on a cold night.
Getting A/F ratio chart on monday. Will post up when i have it. Can't afford a power FC at the moment. I'm not looking at going over 190rwkws with the basic mods (turbo back, cat, Intercooler) Just want good street power.
pretty much no-one has paid attention to what he has said. the car is knocking, that is causeing the power dip. not r&r. there is very little chance of the car hitting r&r at 10psi with stock dump/front and cat. it wouldn't flow enough air. if he did, then when he did put a new dump-cat section on it would make it hit at about 9psi. i'd be getting the fuel pressure and timing checked.
i would also be looking at a new controller, as has been said. it shouldn't bleed off that much boost at 10psi.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
