Hey all,
I took my car down to RE Customs today. Spoke to Ray who was cool and friendly about my results. Basically i got the stock boost level raised to 10 psi. I was told that the engine was knocking. Would knocking occur if the spark plugs weren't regapped? Also when i fully open the throttle the engine seems to splutter (mainly around 5000rpms) before revving clean to redline. Would this be caused by the plugs aswell?
My car is an auto 95 33 gtst. Mods are 3.5 inch cat back and POD. Boost was raised with a bleed valve.
Also what are your opinions on the dyno read out.
Thank you to all that reply.
https://www.sau.com.au/forums/topic/134479-got-my-car-dynoed-today/
shouldnt be knocking with those mods... as mentioned fuel pump would be the only reason as it should be rich as upping the boost
Also maybe look at getting a better bleed valve/boost controller looks like by the time you are making max power it has dropped back to 8.5psi
cant say for sure without seeing your afr but generally with those mods you would see you car richen up a fair bit eg maybe a 11:1 or 11.5:1 if you get the afr and it's above 13:1 i would get it checked out although any good dyno operator should have said something and stopped the dyno session.
But it's an easy task and worth checking anyways pull out your plugs check the gapping and check your coils are in good nick.
if its coffing and farting round 5000 u should gap ur plugs down mine r at .7 sum ppl say its to low but when i had same mods my car was doing this and that gap fixd it 100%
also if in doubt about the fuel pump put a fuel presure reg on it and up the presure to say 45 50 and see if that helps with the pinging if not could be shitty fuel mine knocks (pings) if i run optimax but 98bp ultamate it dosent
I'd think about closing the plug gap to 0.7 or 0.8, but at only 10psi I can't see this being your problem. If your getting a stutter at 5000 I'd be checking plugs, coils, fuel pump and injectors, make sure they are all working OK. I'd also be checking the simple things, air filter, fuel filter etc.
you are definetly hitting rich and retard
dont bother changing plugs or anything else
turn the boost down see if the problem goes away
if so, which im pretty sure it will, time for a piggyback, remap or stand alone ecu
Sorry for the late reply. I run my car on Bp ultimate. Seems to run better than any other fuel. So getting an SAFC should rectify this problem?
Thanks
Well yes but it still seems really low for 10 Psi. I hit 175 with standard boost, std cooler, pod and cat back. I wouldn't up the boost till you at least get a Hi-flow cat and perhaps a dump or split dump pipe. Seal up your plugs to be sure and you should be able to get close to 9Psi without even touching the boost controller.
Your plugs at 0.8 should be fine. Whilst .7 or .6 may seem to fix a problem, it usually only "covers it up". Find the cause of the issues rather than trying to cover them up methinks.
Checked my coilpacks and they seem to be fine, no cracks etc. My plugs are NGK iridiums which are only about 6000kms old. The air filters seems to be fine, its basically new, don't know about the fuel filter though. I haven't changed it since i bought the car 20,000kms ago but it was apparently changed before i purchased it. Gonna look at A/F ratio on monday. Could driving my car around temporary in this state potentially harm my engine? Also can ignition timing be cause of this problem? Does it have to be retarded or advanced when running more boost?
Thanks all
Unfortunately there isn't much you can do to fix the tune of your car without getting a power-fc or some other computer, the computer retards the timing and richens the mixture when it detects the car is running outside the factory specs(more boost).Cars with a catback exhaust can hit rick and retard on a cold night.
Getting A/F ratio chart on monday. Will post up when i have it. Can't afford a power FC at the moment. I'm not looking at going over 190rwkws with the basic mods (turbo back, cat, Intercooler) Just want good street power.
pretty much no-one has paid attention to what he has said. the car is knocking, that is causeing the power dip. not r&r. there is very little chance of the car hitting r&r at 10psi with stock dump/front and cat. it wouldn't flow enough air. if he did, then when he did put a new dump-cat section on it would make it hit at about 9psi. i'd be getting the fuel pressure and timing checked.
i would also be looking at a new controller, as has been said. it shouldn't bleed off that much boost at 10psi.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
