  • Replies 92
6 weeks... what's going on mate?
I sms'd Rob today - he said "Just called them AGAIN - i think i let you know they were due last week but didnt show. They should be sent out today and i should have by wednesday at the very latest". If they keep stuffing him around he's going to let us all call them and start complaining.
If he doesnt get them on Wednesday i'm going to name and shame, this is pathetic.
HTH
Kot
Hi guys, yes as adam posted after more calls I have been told the cats were sent yesterday and I should have wednesday.
Again apologies for the delays but there is nothing I can do about it. I'm dealing direct with the only australian importer of metalcats so we're in the same boat as everyone else who's after these products.
Everyone still waiting has been given my phone number please free to use it as I know I have not been on the forum alot lately. Also feel free to contact PSI if you want to confirm the situation their details are listed on the website here http://www.psiproducts.com.au/
More info, just received an email confirming despatch and have the con note number. Coming through TNT again so assuming they don't f**k up and send it back to QLD again I should be posting again on wednesday to confirm they've been received.
Can anyone who's still waiting pls PM me your address. I have a postal address for most if not all of you but if you can please confirm via PM then it's one less potential holdup.
Thanx
More news, the cats are at TNT awaiting redilvery. I wasn't home when they came yesterday so gotta get them brought out again monday (soonest possible time) with the signed card etc
I'll be able to package monday night and send out tuesday morning. I'll post on tuesday to confirm cats have been sent
Just to confirm, this is for all the flanged cats? not a new batch of cats?
Hi everyone, this is some new news since sending out all of the PM's last night.
I just had an email from the supplier saying that they now have bolt ons back from welding and are packing everything for freight. I should have them all by the end of the week, although given the problems already experienced don't hold your breath...
Anyways just another update trying to keep all informed, will copy this information to PM when I have a little more free time.
Guys, everyones cats have been posted as of today (with the exception of 3.5" bolt ons that have been discussed with the buyers).
As I have said in posts and PM's EVERYONE WHO IS STILL WAITING HAS MY PHONE NUMBER, please use it rather than posting here as I have told you time and time again I probably will not see the posts.
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
