Hey all >_<
My car doesn't have a cat and I've asked in the Forced Induction section but I've had no reply so far...
Which do you recommend and why?
And where can I purchase one from?
I'm sick of the smell and dont' fancy the fine if caught.. I bought the car without one so its time I get one.
I have 3" exhaust..any other info you require?
Thanks >_<
https://www.sau.com.au/forums/topic/134510-catalic-converters/
id put one on.
they rob all of 5rwhp? IF that.
they also put our a terrible smell, and leave black shit all over your car. not to mention the legal issues.
better to be safe(and 5hp less) than sorry.
apparently 'metal cat' are a good brand, but dont ask me where/how much etc :(
was just adding my 2 cents.
Thanks all - I'm going to go with Metal Cat... http://www.metalcat.com.au/
They write this on thier website:
Please also note we are happy to be tested against ANY cat in the marketplace . There has been a flux of outrageous figures claimed with companies not stating what the maximum flow rate on the flow bench is set at. These 'brands' are quoting figures to look good and fool the end user. This especially holds true to the Magic and 'Xforce'Chinese illegal cats . We encourage you to 'TRY" find the CA stamp on the body of their catalytic converter. You won't as it does not exist, as they are ILLEGAL. Why not as an exercize call them and ask them to fax you through their EPA/CARB/Euro test results from factory? And finally , these companies are quoting cfm figures without what the bench flowrate was set at. Why do they find it necessary to lie? The answer is simple, they have an inferior product.
whats the difference between a hi-flow and normal?
i know the hi flow performs better...... but what do u do 2 make it hi flow?
the highflow units generally have larger inlet/outlets on the body of the cat, they also do something with the internals... i think they use smaller holes, but more of them. dont quote me though i could be dribbling shit. :D
$280 is quite a good price for a 3" cat...
i need to go look where my cat is to find out what size i need..
my exhaust consists of 4 different diameter pipes :|
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
