Hi guys,
I know it's not a big thing, but im pretty novice when it comes to cars and don't want to pay a mechanic to 'change a bulb'. Just wondering if it's as easy as it sounds to remove/replace headlight bulbs in an R32 GTST?
Seems one of mine is dead, so have decided to replace both. I have been told you can remove just the bulb itself, not the whole headlight enclosure, and that it should just 'pop out'.
Anyone that can help, or direct me briefly on how to go about this would be excellent!
Cheers fellas.
EDIT: Does anyone also know what kind of bulbs are used? If so, where to get some? Or more powerful ones?
Edited by RetardedMonkey
https://www.sau.com.au/forums/topic/134525-headlight-bulb-change/
You can get at the bulbs from behind the head light. Trouble is that the battery and stock air box can get in the way. There is a screw on large circular piece that is removed by hand, remove the plug and then a wire circlip that holds the bulb in the light assembly.
For r32gtst's you can get either H1 or H3 bulbs so you are better off removing the dead one and taking it with you to a parts shop. The cars with H1's have the bulb mounted in a carrier that you also need to reuse.
They are common enough bulbs, any parts place will have stock. Just don't get Narva or you'll be changing them again in a year.
If you want more power you can get an aftermarket xenon kit, but its not exactly cheap.
If you have H3C bulbs, follow this guide so you can use the more popular H3 model (which you can get Plus 50's in, etc):
http://www.aus300zx.com/tech/lowbeam/lowbeam.htm
There's nothing available in H3C, they suck.
buzzz....wrong.
Ive found a bloke here in Adelaide who can sell me pairs of hc3 for around $25 a pair :(
Unfortunatly he is in the US atm, and wont be back till mid Nov.
Edited by Bl4cK32
what I meant was you can only get shitty generic H3C globes. Also I found some riceboy blue ones that were absolutely abysmal in light output.
Anything worthwhile, like Plus 50's that give you more light on the road where you need it, are only available in H3.
Hence my comment about H3C globes fellating the big one.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
