I've seen too many skylines in Glen Waverley..
  • Replies 50
Originally posted by king_kw13
Hey guys, I hope I don't pee anyone of u off, but I live in Glen Waverley and going to get my R33 soon. I hope u guys will give me a wave rather than a finger :)
nooo! dammnn u! DAAMMMNNNN UUUU! j/k :)
yerr there are alot of skylines around these types of areas (inc. mine)
if u guys do plan a gw meet, count us in....after i manage to fix my car eheh
Originally posted by coco69
eh?  im checking it out?  why?
hey, ive seen an r33 around a few times, same colour as yurs!  that u?
opss suppose to say I have just checked out your ride not badd :)
yeah , im always around glenny, its different to the avatar now. i've got the red 's' front grilli now.. other features are GTR spoiler :)
You live down knox city? heaps of lines in that area as well. I like the new cafe shoppin centre... big changes lately.
pushead, i think i saw your car the other day then!
charcoal grey with gtr-spoiler yeh? are u on P's?
king_kw13: s1, s2!!! stuff that... r32 canes all do0D!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
