Brazilian GP
that was a fcking awesome race!!!!
so glad I stayed up to watch it! :uh-huh:
thought it was funny when Rubens slowed down and pulled over...and they said ppl got up and started leaving LOL
i was disappointed when Montoya went off...but then i laughed when MS did later on hehe
WooHoo! Another Mclarens win! :)
Gotta feel for Jordan though, I reckon it would've made little difference if they won and they need it. Hehe.. and the car was on fire afterwards, must've been pissed off about the results.
As much as I'd love to see Mark Webber get maxium points from every GP, I hate this 2 lap countback rule, honestly, a car which has caused a reg flag accident and can't be driven shouldn't be awarded points in my humble opinon.
ANDREW
Well, if he had started his 56th lap, there is no question that the countback is to lap 54..and he wins.
I've finished a number of races under red flag, and it always shits me that I didn't get to make that one last move on the car in front....and red flag rules (at least in Aus) are implemented so poorly, no-one ever knows if it will be declared at previous lap, restart on current lap, restart race etc etc. One time at Oran Park last year we waited 20 min while the stewards stuffed around deciding what to do - we could have done the whole race again in that time!
Red flag is a bad, bad feeling...but i personally find the green with a yellow chevron worse...
Nothing like getting a perfect start and seeing that MF flag a few flag points down the track.....Or the red and white chequed
:confused: green & yellow?
red flags shit me coz drivers know they can take advantage of it.
one example from last season. Pole sitter gets bad start, so makes overly aggresive move down the inside of 3rd & 4th into turn 2 at Oran Park. Smacks into 3rd place car, both spin, they end up nose to nose in the middle of the track. 2nd place starter is miles ahead due to the accident.
Both kill engines and say they can't move. Since track is blocked, race is red flagged. Since it is first lap, there is a full restart, including dcikhead being back in pole to try again.
In AKA Sprint Karts, if the start has deemed to be unfair or someone has jumped it they put out a green flag with yellow chevrons to indicate to slow down and reform on the track in your starting postions (karts have a rolling start.)
I think your pole sitter might be watching too much F1..LOL...
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
