hey i'm looking into buying a tommy kaira m25 (r33) and was wondering if any one knows what mods exactly are done to these cars ( apart from the visible ones ) if anyone could direct me to a site that shows the specs i.e mods, power figures, times etc or if anyone that has had one knows them it would be really appreciated thanks. :D
https://www.sau.com.au/forums/topic/134574-tommy-kaira-r33/
err I thought some guy was selling one just a week or so ago on the forsale forums? Have a look through them..
Edit; Here it is.. http://www.skylinesaustralia.com/forums/in...howtopic=132916
Apparently it's a bit suss.. but still some pics and info there..
Edited by ignuz
https://www.sau.com.au/forums/topic/134574-tommy-kaira-r33/#findComment-2501680
  • 1 year later...
Inside the right-hand-drive Tommykaira R, the driver is surrounded with evidence of the machine's pedigree. The stock vise-tight bucket seats and stock rear seats are trimmed in trademark Tommykaira red, and there's a Tommykaira steering wheel that's sublime to squeeze. In front and in plain sight is the Tommykaira gauge cluster, which houses, among other things, a 10,000-rpm tachometer with a lofty 8000 rpm redline. Tommykaira also mounted three gauges in a carbon-fiber surround, detailing boost pressure, oil temperature, and by far the coolest one, torque distribution between the front and rear wheels.
To the right of the steering wheel is the ignition. When the key is twisted, the car comes to life with a bark from the A'PEXi N1 downpipe and Tommykaira exhaust, then settles into a glass smooth 900-rpm idle. Thanks to Charles having deleted the catalytic converter and adding an A'PEXi intake, the TKR's voice is slightly more pronounced when clearing its throat, but it's far from obnoxious. This is one of those rare cars with more bite than bark. The slightly massaged twin Garrett turbochargers and 50-percent larger than stock Tommykaira intercooler extract a claimed 465-crank hp from the 2.6-liter engine.
https://www.sau.com.au/forums/topic/134574-tommy-kaira-r33/#findComment-3561284
https://www.sau.com.au/forums/topic/134574-tommy-kaira-r33/#findComment-3562753
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
