shame, targa tom just sold a very well prepped 32.
my105 is the place to go for prepared race cars, but the fact is most cars that are "for sale" are sitting in a garage somewhere and noone knows about them.
If you want to build it yourself, rally import from japan is the way to go, you can get hold of just about anything dirt cheap - and then spend 2-3 times your purchase price on getting it up to scratch.
That is a very large pic.
I'm not serious but would be intersted to know what you think it will go for.
Might be another year or two before I get a dedicated track car.
Sadly there is no where to hook up a tow bar on the R34.
I've always loved the concept of being able to take the tow car out if the track bitch dies at an inoportune time.
Im thinking 18k would buy you a quick R32 or R33 GTSt. Get it on Rally plates and keep the engine pretty std, just completely gut the car and get it down to 1100-1150kgs.
Outside of that your probably best decide on what sort of car your after then ringing up Car Clubs listed on the CAMS website. Often the good buys arent advertised, just sold off within clubs
You might find it to be a good idea to have a track car that has the same sort of driving/handling charateristics as your road car, this maens that when you jump into it at the track, you get back in sync with the car quicker.
I am also looking for a Tarmac race car.
I was hoping to get a fully race preped GT type car from japan as I would expect they would be cheap and well setup.
Does anyone know places in japan that offer these types of cars for sale ?
I already have a CAMS license, so I can import a FIA approved car on Race & Rally rules.
Thanks
you can import a Evo VII these days for under 30K on road including compliance, an early R33 GTSt will set you back 10k on the road... and that's under the regular SEVS import scheme, so it'll be cheaper as a race import.
If you want give me a budget and minimal requirements and I'll fish out some potential race imports for ya.
We just brought in an STi as a race import a couple of weeks ago... don't really list em up on the website unless something special comes up... like this R33 for example. We only look for race imports on request only as you can import nearly any car that is FIA approved (or permitted by CAMS in a motorsport they sanction).
My budget is $20k for a full race spec car. I do not think I am unrealistic in my expectations. I think that a race prepped RWD car from japan could easily be aquired for that money. I have a further $10k to spend on spares and anything that needs fixing.
I have also seen EVO6's going in race trim (rally) for $20k FOB.
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
