Hey,
I think my rear tyres are wearing out a little. I've been launching at 3000 RPM lately and doing big wheel spins, when they used to bite rather quickly.
Where is a good place to get new rubber in Sydney metro? Any brand/model suggestions?
I heard Bridgestone Potenza and Dunlop Formula FM901s were good, the latter particularly in the wet. I have stock wheels and am looking for 225s all around (which is what I currently have).
https://www.sau.com.au/forums/topic/13461-hooligans/
Originally posted by Timmy G
Hey,
You and every other skyline owner on the planet...
Mine are getting rather shagged to.
I've been told that buying good 2nd hand tyres is the go if you want to do weird shit and replace them every 6 months.
There are at least 4 tyre joints in Granville so I'm starting there...
T.
https://www.sau.com.au/forums/topic/13461-hooligans/#findComment-261265
I work at a tyre shop on Sat mornings... Out Richmond way... Im sure if you ask nice enough I could do you a deal on sum real good tyres... :(
Here's my number.. Gimmi a call next Sat 0410564777 ( between 8:30 and 1pm )
Cheers,
Rob.
Also sell mags, do guard lip rolling and suspention set ups.
And have one of the largest ranges in automotive batteries in the west...
Ok, I will stop the free plugging now... :(
https://www.sau.com.au/forums/topic/13461-hooligans/#findComment-261514
Hey Timmyg,
R type rubber (Dunlop d01J, bridgestone re540s etc) require a comitted driver for the road. Best grip, but expensive, noise, wear out super quick, tramline etc etc.
If you're looking for a decent road tyre, I'd recommend falken FK451s, others swear by dunlop fm901s.
https://www.sau.com.au/forums/topic/13461-hooligans/#findComment-261808
I was going to start a new thread for this, though fk it ill post it here.
Every day theres a new post asking for what the 'best' tires are to use, check out http://www.tirerack.com
Has to be 1 of the most comprehensive tire sites on the net that ive seen. Im sure it will be very benifical to all of us.
https://www.sau.com.au/forums/topic/13461-hooligans/#findComment-262309
There's no Skyline listed under Nissan/1996.
Is the Skyline listed under any year?
https://www.sau.com.au/forums/topic/13461-hooligans/#findComment-263368
I did I bit of calling around today for tyres for my Corolla (it's due for rego in a few weeks) and after making about 8 calls in and around the Parramatta area, I found either Mathews Tyre Service (in Seven Hills) or Baulkham Hills Tyre King are the go...
Mathews offered me a choice of 5 brands at $110 a corner (either Goodyear, Yokohama, Dunlop, Toyo or Pirelli) and Baulko Tyre King offered me Falkens for $95. These are prices for 195/50/15's, and admittedly I didn't get all the exact models of each tyre to make complete comparisons, but it's a decent guide considering I'm not gonna compete in any track days (not in this car, anyway...).
https://www.sau.com.au/forums/topic/13461-hooligans/#findComment-264400
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
