RPM Performance - Sat' 31st May Drag Day - post here if intending to enter
Sorry Matt take me off the list .... I haven't got any of my proposed mods done cos I've been too busy so there's no point running (since I ran a couple of weeks ago) .... will definitely be there though for a look!
  • Replies 111
Hey Matt :D
Can you update the first post with the following:
PAID
rob vu ss ute - Monaro CV8
BRUTE - VU SS
Remove the following
LS1-250 - VT HSV Senator
Hyper8 - VX SS
....and
HRT Stroker PAID
Jarrett - VT Senator HRT PAID (Jarrett may be above?)
are the same person.
Cheers
Mat
Yeah John (Munro) mentioned a few wks ago that Keir was going to run his car at this event. I've not heard anything more about it until now. Keir is welcome anytime as far as I'm concerned!
Matt,
I have 3 people paid up today.
Clint32 - R32 Skyline
Alexis Paul Poole Honda CRX
Rob VU SS - Monaro
Ben Siedel's RX3 RPM car.
I spoke to Mike Petrou to invite Keir Wilson with his GTR to the meet and Mike said that he will get back to me. Yeah, for sure, wouldnt mind seeing the 9.38 secs 32 on the track!!
Ivan will contact AIR today & find out about pit crew entry (in particular late arrival) takeaway food options & a few other details. He'll post the info up asap.
Keir Wilson will be running his GT-R :D
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
