RPM Performance - Sat' 31st May Drag Day - post here if intending to enter
  • Replies 111
Matt,
The following paid yesterday,
Anthony Chan (Madman) GSR
Brad Sullivan HZ Premier
Adam Hart 180SX
Jeff Watson Ford Escort
I rang Anna and she said that pit crew coming at 12 noon is alright, because she will leave it to the RPM and SAU crew to police the attendance. Avgas is also readily available on site.
Also, I have contacted someone to do a sausage sizzle for us at the pit area.
Alright, hope everyone have a good day tomorrow!!
Also, in regards to the pit crew, we can bring in as many as we all want to, its pretty much a casual thing as long as there are no walk in public , its fine.
The weather forecast says its all beaut plus the sausage sizzle tomorrow should make it one awesome day!
Oh, BTW, those on the list can still pay at the gates tomorrow as we still have a few spots left.
They charge a lot for avgas at air from memory.
I may be a little late in the morning due to a few problems, will be there at 10 hopefully.
I got my new diff but they used a GTR centre as it is a mechanical type lsd with a 4.3 ratio. But i now need to use GTR driveshafts and GTR hubs, so at the moment the car has no diff, rear brakes, rear hubs, driveshafts and exhaust. So i will be busy in the morning.
Anyone arriving later in the day is fine, Anna AIR said that it will be up to RPM and the SAU( I take it that she meant the moderators of the forum) guys to police the attendance, basically what she meant is that we are not allowed to charge admission fee to the public.
Couple more people paid today
Matt Sullivan ( Bugalugs) R33 GTST
Wayne Fitzpatrick Mazda RX3
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
