hey, was wondering what is involved in installing HKS inlet and exhaust cam gears on the rb25, do you need to change anything with vct or just pull stock off and fit new ones? i would like to know if they can be run with vct. thanks in advance
https://www.sau.com.au/forums/topic/134643-adjustable-cam-gears-rb25det/
You can't really run an adjustable with vvt on the inlet on a 25det. You can run with one on the exhaust. You take the ignition pickup and front cover off, slide the belt off, take off the old pulley, put the new pulley on, index the cams to the motor, reinstall the belt, put the cover back on, and then time the ignition. There is no use doing any of this until you have other mods [fmic, ex, pod, pfc etc] and then it is best done when your at a dyno so that you can set the live centre of the exhaust pulley up for best results and map your pfc to the amount of retard you have dialed in.
i know the how, i have the mods, i just want to know if you have to machine the head or you can just put the pulley on, set for 2 deg advance and thats it till tunetime.I read something about blocking the oil feeds to vct or something?
the cam gears are easily available ut i want to know if you can use it. i know most people do just the exhaust but it would be better for me if i could build my head with both cam gears. Ive tried searching all day but its hard to find stuff when cam is a 3 letter word, like vct. so i just asked.
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
