Boost Dropping Off
Thanks man, yes unfortunately normal bar went on after a minor accident. Smash repairer ordered the wrong version, needed my daily driver back asap so just accepted it. Hoping an aero bar in RH1 pops up for sale soon, I know paint from different cars won't match perfectly but will look good enough
If it is the case that your stock dash high beam light lights up as it should, all you have to do is tap into the power wire for the high beams dash globe and feed it to pin 25 on the Haltech dash. -
I thought you said the stock dash high beams light doesn't light up when you push the stalk forwards and lock the high beams on? -
By BourneToLive · Posted
It did work on the stock dash. Having it working on the IC7 is what I’m chasing. It doesn’t matter to me much, but there’s no information on how to do it out there and people who have done it are gatekeeping the information . it will most likely come up again in the future. -
Yeah ok, so this was an issue prior to installing the Haltech dash. If you want it sorted, time to start chasing the factory wiring to see where the circuit is open. But if it didn't bother you that it wasn't working on the stock dash, I suppose it doesn't matter if the Haltech dash also doesn't work?
