Well, I've split #6 lower injector seal, and the top half of the manifold needs to come off to get the fuel rail off. Trouble is that the gasket was 'repaired' the last time the manifold was apart to replace the O-rings and seals on the injectors, so I really think I should grab a new gasket or come up with an alternative.
Does the RB25DET gasket interchange, or perhaps the Aus delivered R31/RB20DET (NICS) motor gasket? Or is there somewhere that stocks this sort of item? Has anyone has success with the silicone "instant gasket" tubes?
Hey chief, don't even muck around - get yourself a new gasket!
Do it once do it right...Any decent parts shop can get you the right one.
If you are stuck for one try loctite 516 'master gasket' it is a flange sealant that should do the trick...don't just replace one seal either, do them all & it will be done for good with no hassles!
I can tell you a way of making your own, I have been for a while and it works great.
Go down to any auto place and purchase some gasket material, sort of like cardboard its pretty cheap.
Then lay it down accross the intel manifold and get a hammer with a round end on it (a small hammer works best), then gently hit the gasket around the edges and it will cut it away.
Works much better than and gasket goo, just have to be careful when doing it you do not damage the surface of the inlet manifold by hitting it too hard.
The rb25/nics its a different style inlet so its not interchangable.
That or go get fisted by nissan for a genuine.
I wish that were true, because when it had a leaking O-ring before the engine was fitted to the car, we pulled the injectors & had them cleaned and replaced all seals & o-rings. The car doesn't get driven much, and it's only been 3 years/~20K-Km since that work was done. No-6 O-ring is also leaking slightly, but the bottom seal has a split and is no longer sitting in the bottom of the recess in the manifold.
I'll try and find a shop in Aus. which can get the gasket, otherwise I will have a go with the gasket paper (many years since I had to do that! Cornflake box cardboard work well for this as well, but I'll go with the real paper for this).
  • 3 weeks later...
Well - the gasket is available via Nissan for less than $15. Apparently they have seen the light, and carry many of the service items for the imports.
Bad news is that three of my injectors are stuffed - leaking from the body, not the O-Ring.
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
