*******big Aquarium And Cabinet********sold
Guys I have for sale an aquarium
Tank: 5ftx1ftx2.5ft with glass lids all 10mm and a 12mm base [rrp $1000.00]
Cabinet : 5ft raw timber with 3doors [rrp $600.00]
Hood: 5ft raw timber [rrp $200.00]
Filter: Fluval 404 canister filter (brand new) [rrp $350.00]
Light: 4ft light ballast (brand new) [rrp $65.00]
Heater
Power head (for water circulation)
Gravel: 20kg coral sand [$60.00]
15kg of Live rock [$200.00]
1 clown fish
4 chromis damsels
Im located in sydney and it will be pick up only, its a massive tank!!!
Asking $999 for the lot! SOLD
Absolute bargin!!!!
Serious buyers only please.
0420560838
located near parramatta.
https://www.sau.com.au/forums/topic/134762-big-aquarium-and-cabinetsold/
  • 5 months later...
My 4x2x2 came with a 15mm base.
And???
look mate Im selling and your obviously not buying so please go and find something else better to do then bag my sale...
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
