i dont think the ECU goes into close loop (ie uses o2 sensor) during idling
from the doccos i've read for the RB30 ECCS, only above 2500rpm and only at crusing speed. the lights on the ECCS start to flash lean/rich/okay/dead when in closeloop. the RB20 eccs should work similarly from what i've seen
when i had my HD clutch installed they accidently damaged my 02 sensor, i'm assuming this is the 02 sensor every1's talking about.
the 1 thats hard to reach!
nyways at idling, it wud drop in revs all the way down to 0, till the car almost stalls, then it wud bounce up and down from 0 to 1,000 rpm
i've read somewhere you can 'clean' with high temperature like a butane torch or something.... dunno if that would work. o2 sensors have a limited life span and if they rattle they are dead (small chemical plate inside has broken)
if a car is hunting at idling then i dont think its the o2 sensor, but the Auxillary Air Control valve maybe instead (you can disconnect this to see if there is any difference)
yeah there are several ways...
find the wire for the O2 sensor going to your ECU and put a + probe from multimeter on it. put the - probe to the chasis and drive your car. it should vary between 0-1volts. if it stays at 0v its dead
or you can use an Air Fuel meter (various kit forms from Jaycar) and if its 0 then its dead
on the RB30 ECCS if you have the car warm temp, running @ ~2500rpm (no throttle switch in idle), diag mode OFF then the GREEN light should flash/stay on at least if both lights off continously then O2 dead. it may be similar for the RB20 ECCS since most of the software looks similar
That's really weird. My O2 sensor is totally dead (ie reads 0V permanently), but I've got great economy. I've got a SAFC though, which I suppose works off the AFM.
Can anyone tell me when the ECU uses the AFM and when it uses the O2 sensor? Or is it always using both?
think it uses AFM at all times - because it requires 'LOAD' from the VQ map which is measured by AFM to calculate at least the ignition timing and perhaps air/fuel ratio maps (this uses a variation from 14.7 stioch ratio when in different parts of the rev/load range)
matt
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
