hey mate, i have done it on a N/a 4cyl , i wouldnt recommend it for a n/a car and i wouldnt do it on my r33.
i doubt there is much performance ot be had with a street r33 any ways ?? is there?? it would be very minimal if u had a dump full zorst and a high flow cat alrady.
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2505374
Hey guys,
I am aware of punching the center out of a cat is illegal . Im thinking of punching out the inards of my sports cat and replacing it with a 3 inch pipe.
Anybody got any ideas and comments on the matter?
not sure what info your after. you admit you know that its illegal, thats really all there is to it
theres very limited gains to be had
i had one on my 33 T when i first got it
replaced it and felt or saw no difference on the dyno
a very slight deeper note to the exhaust and a little more stinky thats the only differecne between that and a god quality hi flo item
Jimbo
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2505383
if you are in qld you will just have to watch out for the hoon squad. when they are doing a blitz they have a epa station setup and they will tell you to go straight to it and escort you there. they did 1 up here in gympie. had it setup for emisions and noise. went right over the car.
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2505525
lol i saw "cat punching" and the last post by ctjet, it made me think of something entirely different.
I think the noise must depend on the car. A couple of my mates have had theres hollowed out and it sounds sh!t.
Personally I would just get a high-flow.
Edited by shyster
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2505533
When my old S13 was brought into the country, the CAT had been split at the top - gutted out - exhaust went straight through - and finally the cat sat back around the exhaust and welded at the top where no one could see.
Sensor was still sitting in it - though it was ummm loose and rattled..lol
Went to replace it but when I took it over the pits at the RTA for first rego they didnt even test it!
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2505971
The RSPCA will be onto you pretty quick for punching your cat.
PS think about what it does to the environment, and whether you are that selfish to do it for the maybe 5kW extra. Just go buy a good new metal substrate cat.
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2506028
Hey guys,
I am aware of punching the center out of a cat is illegal.
Yeah, I do believe that punching the innards of a cat is illegal. But I don't know, I much prefer punching cats in the face.
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2506572
knocking the car isnt the bet idea
best to get a pipe.
have a look at it all, the exhaust gas would be mising around something shocking, so possible gain... but a better gain from a straight pipe thats evenly flowing
https://www.sau.com.au/forums/topic/134803-cat-punching/#findComment-2507422
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
