Just yesterday my GTS-t started developing weird stalling issues. I turned the car on, revs sat where they normally would (~950) for a second and then dropped to around 300ish and bounced back up to 950 again. It did this repeatedly until it stalled. Started the car again, same thing. Started again and had massive trouble starting it, had to step on the accelerator to get it started. This time when it came to life, no idle hunt, just a nice clean 950 RPM.
Later in the day, same thing occurred however this time I found that if I stepped on the gas and held it at say 2000 RPM, the revs would not drop, they would stay where they are supposed to. I got the car running and then took it for a spin around the block at which time the engine check light came on. I turned around, took the car back home and just before I arrived it went off again and haven't seen it come on since.
Today I changed the spark plugs thinking they may have had something to do with it as they were due for a change but that didn't alleviate the problem. I'm starting to think now maybe the AFM or the TPS might be on the blink but I honestly don't know where to start.
One more thing of interest is that a few weeks prior to this starting I cleaned the AAC valve, I thought that this may have done something but then I thought if I had caused something to go wrong, problems would have started straight after, not now after putting roughly 1000 more k's on the clock.
The car is mildly modded with a PowerFC, cam gear, boost controller, exhaust and pod, please if anyone could help or has any ideas, I'm open to suggestions :rofl:
Thanks
https://www.sau.com.au/forums/topic/134811-idle-stalling-issue/
Well I was told at my last service that the O2 sensor was actually stuffed so I don't think that it would just start like this out of the blue as the PFC is on a closed loop anyways
closed loop means using the O2 sensor..
so maybe disable that feature and test ..
Sorry, I meant it wasn't using the closed loop function. Doesn't matter anyways, found the problem. Looks like it was a TINY slit in one of the vacuum hoses coming out of the AAC valve. Got a new piece, switched it over and hey presto, works a treat!
Thanks for the input anyways fellas, greatly appreciated!
I'll keep that in mind, I've had the same problem the last couple days but I noticed its only happening in the heat (I'm in Adelaide too). At night or early morning its fine, but turn it on during the day when it hasnt been running for a few hours and it wouldnt stay on.
I was worried it may have been something more sinister.
I'll check my aac hoses as you've done first, also ill give the valve a clean, but definitely post again if you have more problems as the heat comes in!
Edited by Mike_
service manual page
i recall reading somewhere it only rich or leans it out a small percentage its not a massive change so it would be odd to make it stall
but the manual says so, so it must be the case. well you can always unplug it, the car should work fine, it will just waste fuel
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
