Hey guys/girls (pfft) ...
anyways I have an R34 GTT and when i block my BOV i get a maximum of 5psi, and it takes longer to build unless its a light LIFT-OFF. (which is why i wanted to remove it, better response).
But i want my full 10-12psi (stock turbo).
I've blocked my lines from the bov, and the boost controller im using is a Turbosmart dual-stage (amazing, never had 1 spike issue with it)
anyway, i just want my full boost without my BOV in use.
help :P
Edited by illusiVe
https://www.sau.com.au/forums/topic/134817-r34-block-bov-low-boost/
lol... Your not blocking off the bov.
By blocking off the boost feed you are allowing it to open easily as there is no pressure on the opposite of the diaphragm, Pressure on the opposite side of the diaphragm equalises the pressure and holds the bov shut under boost.
the best way to block it off is to remove it and put a plate over the top of the hole. then you need to block the return line.
and by blocking it off you won't get better respnse. in fact on gear changes you will have MUCH more lag as the air in the cooler piping hits the closed butterfly, turns around and heads back towards the turbo, and hits the compressor, slowing it down.
the bov lets the air out and keeps the air flowing in the 1 direction.
and at 12psi you wouldn't be losing any boost pressure. if you are want a bit more response you can block up the recirculation hole in the bov. just take the bov off, countersink a hole so that the head of the screw will be flush with the bov. then put a wood screw in.
but you aren't getting the same response. you are only getting 5psi. try the same thing without a boost controller, just off the wastegate (so its 5psi) and see which is better. and you said in your first post that it takes longer to build boost unless it is only light throttle lift off.
yes it takes time to vent, but since your current setup is holding the bov open the air is just flowing straight out. but once you step on the gas again and it buils up enough pressure to open the bov you would lose power, as the turbo keeps working harder and harder, but the boost doesn't rise.
Edited by mad082
last time i take friends advice for 'removing a bov'
my poor turbo :P
so if i do something like this (as i understand it from your post)
will remove bov physically and car will run 12 psi with no leakage :(?
not shown in the pic, i'd also have to block the original hose from the throttle body/intake area thingie :(?
Edited by illusiVe
You only need to throw a plate on the cross over pipe then bolt the bov back over the top of it. Be sure to use gaskets.
But...... Don't fiddle.. Just leave it.
The stock bov is there for a couple of reasons, improve part throttle drivability and to aid turbo life.
in illusive's post, just cut a bit of sheet metal to size and block it where the yellow label is. Don't worry about disconnecting any of the other stuff or plugging anything else.
If you block it at the flange then no air will recirculate, no matter what the diaphragm does. Leave everything else connected so you have no air leaks, and presto.. blocked BOV and it looks stock :)
thanks for confirmation, yer last thing u want to do is put a piece of metal in your engine by someone just saying 'do this' and being unsure.
when everyone was basically saying the same thing, i gave it a shot and it works awesumz.
my noBov mod is proudly sponsored by 1 wasted can of coke.
can of coke ????
hahahaha oh man I wanna see a pic of that !! :)
Anyways best way to block off the bov is to take out the black rubber hosing that connects the bov to the return pipe, go to the local hardware and buy 3/4' (from memory) rubber stoppers for chair legs haha and attach to the bov and the return pipe and do up the clamps and your done.....
I only done this to check if the bov was faulty as I seemed to be loosing boost somewhere...and I was right too I was losing boost but it wasnt from the bov....dont recommend leaving it blocked off for extended periods of time though.
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
