i want h1 6000k but want to see waht they look like as in the blueness and brightness.... get me some pics?
6000K looks like all the merc and bmw lights
if you want blue in it you are better off going for an 8000k but then you stand the chance of getting defected.
best bulbs are the 6000k they are the most common
i will install on my car in the next couple of days and i will show you what it looks like
https://www.sau.com.au/forums/topic/134840-hid-kits/page/4/#findComment-2590271
  • Replies 66
anyone who has installed...
please post pics of lights facing a wall/garage door... etc... from a fair distance. Would like to see light cut-off
thank you
https://www.sau.com.au/forums/topic/134840-hid-kits/page/4/#findComment-2612378
thank you
https://www.sau.com.au/forums/topic/134840-hid-kits/page/4/#findComment-2612382
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
