Exhaust shop in Brisbane
STU E
 Share
Can anyone recommend an exhaust shop in Brisbane to supply & install a turbo back exhaust? I already have a 3-inch cat back Kakimoto setup and am hoping to make some good power gains. Any advice would be greatly appreciated
Originally posted by hungry6
Custom exhaust at meadowbrooks does awesom pipes. If u have to screw out the very last of those horses in the motor.
Got a Ph num, or address?
Originally posted by pinto
Rob Bliss at Geebung
3265 2044
I second that these guys do quality work, know skylines and have great prices. They did the exhaust on my R33.
Recommended by Gavin Woods at Autotech who I am sure Nismo Girl has told everyone all about :D
i just had a turbo back done by rob bliss and wasn't all that impressed, they welded the whole thing as one piece so its a nightmare to take off!
They came highly recommened and the twin dump looks really nice on the outside but on the inside its not all that effiecent, i reckon drift king did a better job on my dads r33 but it cost twice as much.
heh, not that it makes much difference with my pissy little t28 anyway :D
Guest 570CK
No comment. My dump pipe cracked and exhaust bangs
Mate of mine. Dana with a blue s15 200sx got a exhaust done at Jack Beedhams.. Got some great result with single dump pipe..
Think it was cheap too.
Might get him to make up a dump pipe for my gt35.
CES, always gets great results in performance pipes
The test & tune i was in my gf's jungle green s14 200sx! still has std wheels etc. Was talking to you @ drag combat about r33 as at the time gf was looking at buying 4 door R33 but saw the sx & wanted that instead!
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
