Hey,
I’m Ben and I’m 18 and live in Brisbane. I’m extremely into skylines and im looking into buying my own r32 gts-t in the next 2 weeks and joining you guys in the sau community.
I will be buying a stock r32 so id like to get a body kit (amongst other things) for it, what type of kit should I get the Price isn’t an issue. If u know any websites, which has a variety of kits, I can look at please reply with the URL or the name of one that you like for me to look up.
Thanks in advance
https://www.sau.com.au/forums/topic/134885-little-help-plz/
Oh ok cool.
Will you be going performance or just making it look good.
Putting a bodykit on it straight away will look pretty strange on a stock r32.
Maybe go for some wheels first and then a bkit then concider lowering it. Theres a certain order of things you need to do sometimes.
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2508150
i same body kit first, then u know what size rims will fit, then how low u can go.
i know
www.nismo.com.au have kits,
and
www.carmate.com.au
but i dont know how good the sites or quality it.
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2508305
ahh wonderfull thanks for ur help well yeh i wasent only going to get a kit just its one of the things i needed a little help with ill be putting an exhaust, kit, wheels(rims tyres ect) steering wheel, shift knob, short shift kit and tinting those plus a few more when i get it just to get me started any way.
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2508442
If the engines stock what do u need a short shift kit for :dry:
You should do the engine up a little bit before shit like that.
Full exhaust system: Larger diametre dump pipe, Headers, New cat, And a full cat back with a new muffler ;)
Pod filter and maybe cold air intake,
Boost controller and crank the boost up on the stock turbo to about 10 - 12 PSI
and a new BOV.
Thats just what id do if i had a gts-t but im not allowed one :wave:
Ask people on here about what the best brands and prices are and where/where not to go.
Also things like gear knobs and steering wheels arent to great unless you plan on turning your car into a boyracer, But its your car so go hard out :wave:
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2508468
righty o thanks
do u know any websites with definitions of each mod you can get or can u make me a list of stuff which most people have got done so i can look it up my self.
sorry if this is a inconveniance im just trying to learn :D
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2509128
If the engines stock what do u need a short shift kit for :kiss:
Full exhaust system: Larger diametre dump pipe, Headers, New cat, And a full cat back with a new muffler :D
and a new BOV.
Your exaust system controlls your car emissions.. If you know how an engine works then you will know what the exhaust is used for.
Pod filter or air any sort of intake filters are your source of air induction, Again if you know how an engine works you will know why you need air intake.
Boost controllers set the amount of pressurised air being put into the engine from the turbo.
A compressor bypass valve (CPV) also known as a compressor relief valve is a vacuum-actuated valve designed to release pressure in the intake system of a turbocharged car when the throttle is lifted or closed. This air pressure is re-circulated back into the non pressurized end of the intake (before the turbo) but after the mass airflow sensor.
A blowoff valve, (BOV, sometimes hooter valve) does basically the same thing, but releases the air to the atmosphere. This creates a very distinctive sound desired by many who own turbocharged sports cars. Some blowoff valves are marketed with trumpet shaped exits that amplify the "psshh" sound. For some owners this is the only reason to fit a BOV.
http://en.wikipedia.org/wiki/Internal_combustion_engine
http://en.wikipedia.org/wiki/Turbo
http://en.wikipedia.org/wiki/Blow_off_valve
http://en.wikipedia.org/wiki/Boost_controller
Hope this clears up some things
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2509251
i bought a stock r33 and built it up myself. trust me it isnt cheap and it never ends. if you can your way better off buying one in good condition but already with a kit youd like. Talk to steve69s@f**khotmail.com he's got a sweet r32 hes looking to part with but hasnt advertised yet.
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2509647
car isnt for sale at the momment guys.. if i change my mind will let u all know, but heres a pic i took 2days ago off my camera phone just so u's can see. :ermm: thanks for the interest all the same.
& good luck 2 Destero for finding his skyline.
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2513214
dont get a kit without rims, it'll look totally stupid, and u'll get no "respect" wat so ever, which is what i think ull be wanting.
get kit and rims and suspension at the one time if possible. kit wise id go a do luck kit, with prolly some do luck rims if ur after look. then ull need it re-sprayed.
then exhaust, caus itll look ghey with a kit, rims, suspension with the stock exhaust.
then pod filter. boost controller & aftermarket computer. then some slotted rotors, good pads & decent fluid.
thats how i went with my R33, which ill tell u i had BEFORE i got my licence, and now im 19 and have an R32 gtr thats almost finished being built :ermm:
oh, and dont go driving like u stole it, caus u being inexperienced WILL crash
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2513431
Why does everyone think a pod filter is better than the standard intake?? There have been countless tests of these filters and the winner was always the standard intake with an aftermarket panel filter!!
And the BOV is going to draw too much attention so if you can afford it, get the Stealth from GFB as it can be hand-switched between loud or full plumb-back settings. If you get an exhaust, do it right the first time and get good quality dumps from the turbo, an aftermarket cat that won't restrict the flow and a good solid cat-back exhaust that is legal!! First thing they look for is the BOV followed by the exhaust!!
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2513546
Depending on what you want first here is a list of the common things to change to get it up to a beastie in the order I did them (sort of anyway).
Air Filter
Exhaust
Shocks and springs and pineapples
Strut braces
BOV
ECU (computer)
Boost Controler
Front Mount Intercooler (FMIC)
Fuel pump
Fuel pressure Regulator
Spark plugs Timing belt and water pump
Went back to standard BOV
Brake booster stop
turbo
Coming soon (or later)
disc rotors
injectors
HD sway bars
You may want to make it look good first, that is up to your own taste, I'm quite happy with the look, but the bonnet with the wheels was a great improvement and I dont have plans for anything else, whatever you do DO NOT use fibreglass for a front bar or side skirts, it just doesnt last.
https://www.sau.com.au/forums/topic/134885-little-help-plz/#findComment-2513675
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
