hi there
i have a AP engineering apexi power fc on the way to suit rb20det - only problem is - i know that the loom is slightly different from 32 to a31 and sensors possibly
good example is afm on ceffy is direct fit to z32 with afm plug having the rectangle one...
WILL THIS FIT STRAIGHT IN AND RUN - or what do i have to do? :S get a 32 loom ( i f**king hope not)
https://www.sau.com.au/forums/topic/134887-power-fc-in-cefiro/
should fit in fine...
put it this way
i had original cef loom...
put in an r32 complete engine... retained loom and ecu... just chopped coilpack wiring loom thats all
btw i hope you got it for under 1300 huddy with handcontroller...
i had a AP engineering one in mine, no probs :D
PS, anyone with a stock Cefiro AFM, sell to me, cos the 32 one im using (using 32 plug on cefiro loom) is just shitting me to tears :P
also need to retune my stock computer (in which i think is a 32 computer too). will all this work together once its retuned? or will i need to change stuff around, as since ive put the comp and AFM in its idleing around 3 to 4k :S
Edited by A31cefiro
