hi there
i have a AP engineering apexi power fc on the way to suit rb20det - only problem is - i know that the loom is slightly different from 32 to a31 and sensors possibly
good example is, afm on ceffy is direct fit to z32 with afm plug having the rectangle one...
WILL THIS POWER FC FIT STRAIGHT IN AND RUN - or what do i have to do? :S get a 32 loom ( i f**king hope not)
has anyone else done this before?
https://www.sau.com.au/forums/topic/134888-power-fc-in-cefiro/
I'd say any ECU that works on an R31 GTS-R will work on a series 1 A31 ceffy
as far as i know the cefiro/skyline loom differences are plugs and nothing more. if you have a look at the wiring diagram i dont see you having any problem.
i plan on running an ecr33 power fc on a cefiro with laurel de (originally rb20e) loom with a skyline head and rb30
make sure you get the numberplates "Frankenstien" >_<
wouldn't the AFM signals be different though, as the R32 and A31 AFM's are different?
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
